L1975NW Issues...
    Re: L1975NW Issues...
    Just curious, but at the bottom of post 15 you stated that the R210 is stamped "1000". If yes, then that would be 100 ohms. If you're getting fluctuating values, then you may have to remove it from the board to properly test it.
      OK so I took it out and tried to test it but get no reading on it at all. The meeter will give me a random number for a split second then shows infinite.
      Also went and tested the other resistors and all showed up as the numbers on the top +-5%. There were a few with different readings
      R216- "2202" - 700 - 20k setting
      R233- "2202" - 700 - 20k setting
      R206- "1000" - 100 - 200 setting (that is right next to the controller, and I guess it's good)
      R139- "1302" - 1160 - 20k setting
      I have a BUNCH of other circuit boards that I can grab things off of. To replace R210 I need a "1000"/100ohm resistor?
        Wow, until I saw jetadm123's post, I didn't realize that the OP edited his original post 33 minutes afterwards.
        Hint. Once I read a post, I don't go back and re-read it again unless I need info. So if you have new relevant info to add, start a new post. If you edit a post because of grammar or spelling, that is fine.
        And yes to everything jetadm123 says and more. He knows this board better than I do.
        --- begin sig file ---
        --- end sig file ---
          Okay well now I feel really stupid....
          Well, after some research I found out that the Q210 resistor is actually "10R0" and not 1000. THEN I figured out that I don't have fuses in the F locations, instead I have 0 resistance resistors........
          SOOOOO that explains why they are not blowing from the over current.
          Now to top it all off I'm SURE because of those resistors I have caused havoc to the lines for the Q206 FET and is causing it to overheat and fail.
            That is a 10 ohm resistor as selldoor mentioned in post #17.
            How to read codes.
            http://www.hobby-hour.com/electronic...-resistors.php
            Or use the calculator.
            http://www.hobby-hour.com/electronics/smdcalc.php
