Acer AL1912 LCD PSU fix
+ More Options
Posts
  • otoluk
    • Feb 2009
    • 84
    • Latvia
    Another LCD display with bad caps.
    Symptoms: Dead, doesn't power on
    Board: 715L1142-3-AUE year~2005
    Fix: Replace bad Elite caps C814,C185 (16V 1000uF). Seems they fail sooner because are too close to heatsinks. It would be better to solder them not so close. Didn't replace the shield maybe it will help to stay cooler, is it safe? .
  • JesseKnows
    Re: Acer AL1912 LCD PSU fix
    You did not include a picture of the shield in question, so it's hard to be definitive. However, since a monitor is typically enclosed in plastic there is no danger of physical harm. However, shielding is used to prevent interference with other electrical devices, especially radios, cordless phones, cell phones and the like. You know, the FCC notice that we do not read in the manual!
    • brethin
      • Dec 2008
      • 1907
      He isn't asking about RMI shielding, he is asking about heat shielding so your off topic.
      Caps are effected by heat yes, always replace caps in high heat areas with caps less prone to failure due to heat. Provided shielding is just that and rarely can be replaced with better shielding as far as heat goes, though adding some type of fan can help a alot.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4961
        • New Zealand
        Mmm It's stupid how they put them above the heatsinks, so more heat can rise into them.
        Maybe they do it to make sure the capacitors die off quickly? There's probably some black art to it to ensure it fails 1 week after the warranty expires...
        -David VanHorn
        • Radio Fox
          • Jan 2010
          • 281
          Originally posted by brethin
          He isn't asking about RMI shielding, he is asking about heat shielding so your off topic...
          Like JesseKnows, I also thought otoluk meant the RF shielding that covers the circuit boards, and agree with what he says.
          What do you mean by heat shielding?
          ________________________________________________
          Invisible airwaves crackle with life
          Bright antennae bristle with the energy
          • Agent24
            I see dead caps
            • Oct 2007
            • 4961
            • New Zealand
            I have never seen a heat shield on a monitor, I also think otoluk means RF shield.
            -David VanHorn
            • japlytic
              • Oct 2005
              • 2086
              Good repair job, but I recommend replacing all of the electrolytic capacitors on the power supply board. You can replace the 400/450V unit if you want; it depends on the manufacturer and series.
              With the electrolytics near the heatsink, you can place them lying against the board so that they are away from the heatsink, just like the 400/450V unit.
              • otoluk
                • Feb 2009
                • 84
                • Latvia
                Yes, I meant the metal frame that covers board (RF shield). OK, next time won't throw it away.
                I replaced all Elite caps, except the 400V one (but keep it in spare) , should update the first post accordingly. Monitor still works 24/7 at my workplace.
