Sony BDV-E4100 stucked / no image on hdmi / doesn't respond to anything
  • sicilianul
    • Jul 2014
    • 70
    • Romania
    I have this blu-ray player which is effective stucked. It responses only from power button. Only a message shows on the screen "BD/DVD" and nothing happens, also no image on hdmi. The dvd tray could be ejected but nothing from here.
    I know it's a software issue, tried allready with powerbutton + Volume -
    Tried with network cable plugged, no update.
    Any ideas ? Or someone who has firmware dump and I could reflashit ?
    thanks!
  • rimwall
    Sony KD-65x7500D - double image - Tcon or Panel?
    by rimwall
    This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
    I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
    11-18-2025, 02:09 AM
  • NSkyLab
    Sony XBR-65X900F black and white image on one side (fading saturation)
    by NSkyLab
    I though I've seen all possible kinds of failures but this one is new...
    Colors saturation is gradual.y fading out on the left side of the screen (all colors are fading out). While B&W image is looking good.
    I tried replacing TCon but nothing changed. So this is looking like the panel failure. Is there a chance it can be fixed?
    Any useful measured can be done on the panel's narrow pcbs? Is there may be something similar to taping trick to fix this issue?...
    10-05-2025, 07:37 PM
  • domix
    Sony KD - 65XF9005 - No image, sound OK
    by domix
    at tv KD - 65XF9005 i have a problem.
    Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
    is this a common problem for this tv?
    i attached pictures of inside. Supply board looks okey, no blowed caps....
    07-21-2025, 06:37 AM
    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-12-2024, 02:20 PM
  • Dreamcazman
    Sony KV-XJ29M31 CRT TV - Very dim image on turn on
    by Dreamcazman
    Hi all, I recently picked up a Sony KV-XJ29M31 CRT TV (BG3R chassis, Australian model) cheaply & completed the RGB mux mod on it for some retro gaming. That worked great, however, I have another problem which I hope someone can help me with or at least steer me in the right direction.
    Basically, the issue is when it's cold, it takes a while (like 2 mins) for the picture to come up. I think the image is there, it's just very dark or dim. I can hear the degaussing sound & I can change inputs & hear audio but no image.
    Once it's running properly, it keeps...
    02-28-2022, 07:47 PM
