Pioneer PL-A25
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Pioneer PL-A25
    Hi can anyone help me, I have been sorting through various boxes and found the above turntable, look fairly old, I cant power the unit up as the plug is missing, I'm being thick but two brown live wires?
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Re: Pioneer PL-A25
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      Re: Pioneer PL-A25
      • Dobsuk
        Pioneer turntable tone arm adjustment
        by Dobsuk
        Hi all. I have Pioneer PL-Z460 turntable but have some issue with the tone arm.
        When the record finishes or stop it manually the arm does not go back all the way to the rest. It stops just short and then decends down onto the base. Is there an adjustment to make the arm go back a futher 0.5 cm?
        There is only one screw at the base of the arm but it is for height adjustment:
        Any advise please?...
        08-18-2022, 12:41 PM
      • EduCabral
        [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
        by EduCabral
        I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
        While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
        🔧 Details:
        • Model: YT-M06
        • Interface: Pioneer 1
        • MCU: Fujitsu MB89F202
        • Goal: Find a valid .bin firmware file or memory dump from a working unit
        I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
        07-15-2025, 12:26 AM
      • pixelcap
        Pioneer Kuro Pro 111FD 8 red blink error
        by pixelcap
        Pioneer Kuro Pro 111FD 8 blink red LED.
        I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
        So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
        based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
        10-06-2024, 11:26 PM
      • RatherLoopy
        Pioneer VSX-44 receiver HDMI dropouts
        by RatherLoopy
        I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
        I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
        And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
        05-26-2023, 03:54 PM
      • Evets
        Pioneer sg530
        by Evets
        This forum has been so useful to me and I thank all the people who have helped me in the past.
        I'm now in need of some more assistance, I have purchased a Pioneer sg530 graphic equaliser to add to my Pioneer X-G7 hifi system. This equaliser was a factory option on this system but as this was purchased second hand I didn't get a user manual. Searching the internet has been fruitless, can anyone help with a schematic of how this should be wired into the system or possible a copy of the user manual.
        07-30-2024, 07:18 AM
