Re: soundcraft spirit m4 mixer troubleshooting
Yes khron,
to inject just past the bad point, so I can look for further trouble while I wait for the pieces to arrive... do you think that's a bad idea?
I allready put a little pot at the tracer, i'l just do the same on the injecter...
just a blocking cap should do it .
you really need to have control over the level . something with a vol control .Leave a comment:
For signal injection, (in)to where? Right after the point the signal gets lost, or..?Leave a comment:
yes, it is. I am blissfull.
It's like a new dimension opening before my eyes! Now I got to a point where the signal goes bad, and further on I just can't keep tracking.
Is it the time to build a cable for signal injection? Is it as simple as picking up a jack and shoving a blocking cap and some resistors in between like the tracer?Leave a comment:
Sounds like progress
I recall 3-4 years ago, buying a Soundcraft FX16-II that had gotten something spilled on it (i might be wrong, but i do recall i bought it as faulty). Actually yeah it did, i'm starting to remember having to "patch up" some power traces going to opamps, that had been corroded by whatever it had "drank". I might've had to replace an opamp or two as well, but it's been a long timeLeave a comment:
hey, I took those resistors, but out of circuit they seem ok.. they are r592, r593 and their couples at the "P/B replaces mix"(master A page)
I also got a weird resistance reading at the resistors after the pan pots at mono at mono channels (i'm sticking to those for now), but just like the ones before mentioned, I believe the circuit is fooling me, since they all have the same readings...
Signal vanishes around the Opamps, they have power, but not much sound after r457(mono input cannel 1).. dunno if it is because of it's value or what.. tomorrow I'l tackle it again.Leave a comment:
well done keep searching ..Leave a comment:
hi there I'm back,
It's too late to look for a stain, I've had it for so long sitting on the shelf, when I picked it up again I gave it a little brush. That was before knowing it got wet. But it was a good idea, thanks, I'm taking a note for the future.
Now, I had the signal tracer that was linked at the beginning, but I had to make a new one with a little potentiometer because the only battery amp I have right now is one of those eggy mp3 speakers, with no volume control and only one miniUSB input. Done.
So now i'm starting to test it, and for a first check I tried eq's and gain pots. And it sounds! ^^
Following the scheme I managed to find a couple of bad resistors for now, but I don't think that's the major trouble... I'll grab a cup of strong tea and get on it.Leave a comment:
see if you can find the stain where the water got in ..it might be a clueLeave a comment:
yes it's late...
I have the signal tracer still unused, tomorrow i'l check out what it does.Leave a comment:
i dont have the brain power right now to start working out why someone did all that to it . best guess is grounding problems .
i think its best to narrow it down into sections starting from power supply then input boards .
you need a signal tracer or scope really ..Leave a comment:
ok, on one side I'm missing:
LK58
Resistors: 37,62,223,224,334,335,364,378,397,455,475 and 666
Capacitors: 228,258,261,273 and 317.
And on the other I have this extra:
A link from R547/C313/TR15 to pins 5/6 of CN8.
An other from C315 to gnd, (the screw beside CN8)
Then CN9 pin 2, is sent along a wire through the back of the board to the next board, to a point where it should join R79/R80 to gnd, but the line that goes to gnd is cut off.
On the same CN9 pins 5,6 also go through the back of the board, to c11/c18, the line going to gnd is cut off aswell.
These 3 pins are gnd so they are all shorted together.
4 links at what appears to be return gains,
R258 to R177,
R257 to R183,
R264 to 189,
R265 to R195.
And the last is a wire that goes from the second screw at the top of the top board, trhough a 75ohm resistor to ring in L monitor out and another 75ohm resitor to ring in R monitor output.
That's all I could work out for now. I don't know Who did this and why, I'll try and find out. But it seemed to work fine untill it got wet at a party. Or so I've been told.Leave a comment:
I'm back, and it appears now the peak lights aren't staying on :S I've tried a couple outputs and it aint fine though.
Ok agent, I'll do that after dinner, my turn to cook today, I'll make a little diagram of what links where and also I'll write down all the wee resistors and caps missing, and we'll see from there.Leave a comment:
I think what needs to be done is a check on the schematic and find where these wires have been connected and try to find why.
They could be to replace blown tracks, part of a legitimate conversion/mod, or some bad attempt to workaround a problem they couldn't fix.
The fault you're seeing now may be related to the original fault if these wires are indeed some repair attempt.Leave a comment:
ok, re-connected the resistors, and now the 4 return peak leds light up :SLeave a comment:
Okay lads, I woke up early to do the homework before i get to work, here are the links to the pictures.
back side overlook
Link part(wire added thinking it had tipped off, and re-disconnected when I saw the next parts)
resistors missing beside cn6
wires to ground from r547
back side closeup, resistors wired to ground(extended to the screw beside JK9)
I also realized the two resistors on the last pic, were split in between them, where they join the green wire. I'll replace those and see, before I re join LK58.
With this done, I will be back at noonLeave a comment:
i must sleep too ..yes some pics will help here ..the schematics are presuming the unit is in the same place as i am ...Leave a comment:
It's way past my bedtime, I'm not seeing right and starting to mess things up. I'm going to bed, tomorrow evening, with time, I'll make a few pics, try to upload them, and explain you what I have here.
Because as I was taking the board appart to solder that link i had a closer look at the board from behind and I saw that it didn't go to gnd, but to a resistor that isn't there, and a few other odd things.
see you tomorrowLeave a comment:
skimming through the manual it appears these grounds are floating and not connected to the chassis .Leave a comment:
am thinking someone was trying to tame ground hum .. so long as something is connected between the grounds it should at least produce soundLeave a comment:
by BektronicsHello dear audio friends.
I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
Thanks in advance if anyone can help me with this schematic.
Of course, all information about this digital mixer and possibly references...-
07-24-2023, 06:40 AM -
by blues_spiritHello from France,
mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
Do you think this is feasible for me? I... -
by zenHi all
This is my next project .
Rebuilding PSU & require values of R36 & R47
Both measuring around 650R ....-
by ThermaltakeHi, I got Behringer Xenyx 1204USB mixer, and in the morning mixer was working fine, but when I came home from bike ride I turn it On but nothing happend. Phantom switch is working because red light is On, but other switch no respond.
I brought mixer to my friend today who is electronic expert and he will tell me if it's the button or something on power supply that died. But I am 90% sure that it's power button. My question is, is it possible to put some better quality switches on that mixer than the ones mixer came with, I found them very cheap and low quality.-
by dicky96Hi guys
I'm trying to repair this powered mixer. Sorry this is a bit long but I want to give as much info as possible to help get an answer,
As soon as it powers on the protect light comes on. There are relays that connect the speakers to each channel of the amplifier but they never click. If I connect a 60W light bulb in series with the mains supply it comes in bright then goes to maybe 30-50% brightness - it seems to dim a little further over time
I have power to the amplifier, I think it was as about plus/minus 50-60V for the main amp, and plus/minus 15V...-
- Loading...
