Hello people
I have this soundcraft mixer, but I don't know what is wrong with it.
So I plug it in, and connect an input to first channel with a music source, and first tried the monitor L output. turned up all pots beyond the middle point (except pan) untill I managed to get a minimal output signal, totally distorted.
The same happened on the R monitor, and all other outputs.
Except for the earphone output, which throught my earphones, sounds like a synth machine cooking them. Not gonna try that for long.
Also I tried putting my headphones into direct out, and everything was working fine through there, all the EQs and everything, so I think the channels are ok,
I opened it up and had a visual inspection, nothing blackenned, bulged or burnt, at eyesight. I think next would be to check the PSU voltages, but I don't know what they should be... or if I should go ahead and assume they are ok since direct out is ok... I looked for a service manual with no luck, anyone have any idea where to point the finger?
Thanks in advance!
Thanks in advance!
