Toyota / Pioneer amp wiring diagram required
  • zen
    • 511
    See picture
  • gabri2211
    I'm looking for the wiring diagram for led monitor model DHI-LM19-L200
    by gabri2211
    hello everyone, I'm looking for the wiring diagram of this led monitor.
    the model is DHI-LM19-L200, but I think that any other diagram of a DAHUA monitor could be equivalent.
    I really hope that among you someone can help me to repair this monitor, the screen is black, it doesn't seem like a backlight problem.
    I see the presence of 12 volts, 5 volts, but without a diagram the repair is very difficult.
    thanks to those who will answer
    12-10-2024, 04:37 PM
  • rayane
    wiring diagram for electrofusion welding machine elofit nupigeco
    by rayane
    please i need shematics of electrical wiring diagram for electrofusion welding machine elofit nupigeco , thank u .
    06-26-2022, 06:29 AM
  • hs5424
    Dynacord powermate 1600 block diagram.
    by hs5424
    Hi All,
    I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
    The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
    07-31-2025, 01:35 PM
  • zen
    Vsxlx305 , pioneer ( us model ) digital board required
    by zen
    Hi all
    Customer shipped this amp over & then connected to UK mains.
    As well as PSU , damage spread to digital board & killed the MCU .
    Any ideas , or a contact for spares ?...
    07-27-2023, 05:45 AM
  • Bushcat
    Pioneer PL-X9 motor speed control wobble
    by Bushcat
    I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
    Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
    BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
    05-24-2023, 03:36 AM
