SAMXON - different case sizes?
  • zuhr14
    • Dec 2013
    • 23
    • Antarktis
    i found, that many of SAMXON(and not only SAMXON) elyt capacitors has a different sizes than the datasheets say.
    Old MB MSI K7T Pro2(lite): (purchased as new in year 2000, original)
    SAMXON KM 10V,3300uF,105°:
    - measured size is 10x25, in datasheets is 12,5x20.
    http://www.tme.eu/en/details/km3300_...n/km-3300u10v/
    -here is also the same size 10x25 as onboard caps (it is real size, no bug in descriptions - i have it from they)
    Power supply Chieftec CFT-700-14CS (purchased as new,original):
    SAMXON GF 10V,2200uF,105°-measured size:10x25,, in datasheets is 10x20.
    SAMXON GF 16V,2200uF,105°-measured size:10x30,, in datasheets is 12,5x20.
    next:
    http://www.tme.eu/en/details/gt4700_...n/gt-4700u16v/
    http://www.tme.eu/en/details/km1500_...n/km-1500u63v/
    -these capacities not exist in sheets
    etc..
    TME is not official distributor, but if every second capacitor is potential FAKE, it seems strange...
    The same - on mentioned branded boards.
    -all from this is FAKE or any special/modified/undocumented versions ??
  • Jooo
    • Oct 2011
    • 222
    • Finland
    Re: SAMXON - different case sizes?
    Custom order
    • mariushm
      • May 2011
      • 3799
      If you buy big enough quantity you can request a custom batch with the diameter you want.
      • zuhr14
        • Dec 2013
        • 23
        • Antarktis
        THX for info.
        Is TME here credible/verified for buying of capacitors?
        (They not provide any info, that these capacitors is in category "custom/special")
        • Jooo
          • Oct 2011
          • 222
          • Finland
          TME is very large supplier of electronic components. I have ordered from them before and had no problems.
          But Samxon KM, GF and GS are bad series of capacitors, I wouldn't use them.
          TME also has Panasonic FC capacitors which would probably be much better choice.
          • zuhr14
            • Dec 2013
            • 23
            • Antarktis
            Yes, top mentioned two GF caps in Chieftec PSU was bad - here is total of 9 GF caps! It must be replaced(but it will be hard work - in the PSU is a little space and 3 massive overhanging aluminum radiators overlap almost everything)
            KM series caps will be replaced.
            I'll be back to the two capacitors from TME:
            1/ GT 16V 4700uF 16x25 - suspicious (what is it?)
            - R.C. is not specified = unusable
            - capacity is very out of GT range
            It seems as 100% KM series, not a GT (case size+capacity)
            This capacitor is possibly fake(KM(?) with GT cover) , not a custom order.
            2/KM 6.3V 1500uF 10x16 - suspicious
            - no sheet info,
            It seems as 100% GC series, not a KM (case size+capacity)
            This capacitor is possibly too fake (GC(?) with KM cover) , not a custom order.
            It is not very credible for me. I can´t this nowhere verify - I will not try luck.
            Boards manufacturers may use special size of caps (for PCB design), but TME?
            • Jooo
              • Oct 2011
              • 222
              • Finland
              I'd say very unlikely for them to be fake.
              TME is mainly directed for companies, who may order thousands of capacitors at once.
              Consumer sales are mostly a "side business"
              If someone requests a big enough lot of custom capacitors TME will most likely go through a custom order.
              Samxon are cheap capacitors anyway, so it would not be worth the risk to fake them. TME would lose it's reputation and big customers by doing that.
              • zuhr14
                • Dec 2013
                • 23
                • Antarktis
                OK,but why they do not provide at least BASIC information for this?
                They refer to the datasheets, in which there is no mention of the product.
                R.C is an important item. If not provided, caps is unusable.
                Where I can use this caps without known specs or where can I find the specs?
                If it was a special order, it would not have been available to the public (without giving specifications.)
                Is probably necessary to request TME for comment (for clarification).
                • mariushm
                  • May 2011
                  • 3799
                  The technical parameters of these custom capacitors will be very close to the ones in the datasheet for the same capacitance and voltage rating.
                  • tmiha71
                    • Apr 2010
                    • 130
                    Problematic size, ~4% downsize... V=r*r*PI*h
                    10x30 2356,1925 mm3
                    12.5x20 2454,3671875
                    Some manufacturers call that downsize, and endurance is usually lower than original size...
                    • zuhr14
                      • Dec 2013
                      • 23
                      • Antarktis
                      I sent email question to TME (2x) and waiting for answer. Long time and no answer from they..
                      If is everything okay, they would comment on this, but they are silent. It is suspicious..
                      • mariushm
                        • May 2011
                        • 3799
                        Keep in mind a lot of companies were with reduced staff since Christmas.. people taking holiday between 25th and the 3nd.
                        Emails probably added up and it takes time to process the queue, or they probably sent emails to manufacturer for details before answering you, you never know.
                          ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                          This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 10:50 PM
                          ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
                          This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 11:05 AM
                          ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
                          This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
                          This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                          ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                          This specification for the ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX461UN-E1042R-CASE boardview and UX461UN-E1042R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-06-2024, 07:07 AM
