Lenovo ThinkPad E14 Gen2 password
  • SysGhost
    • Mar 2021
    • 12
    • Sweden
    Trying to remove the admin password on this Lenovo E14 Gen2.
    Flash chip: Winbond 25Q256JVEQ - extracted with a CH341A reader/writer. Detected memory type: 4019 (33554432 bytes)
    I do wonder if anyone can give some pointer. What is the method one go about to patch a typical locked bios file? Where to start?
    So far I haven't found much information on these laptops. I suspect they're quite fresh on the market. At least the Gen2. (Gen1 has a different motherboard and a slightly different flash chip)
    The lenovo_autopatcher did not work.
    Gave: "dump.bin is corrupted or does not contain a valid dump." after the second stage. [2/2] ...
  • SysGhost
    • Mar 2021
    • 12
    • Sweden
    Need a dump of Lenovo Thinkpad E14 Gen2 firmware.
    Any owners of Lenovo Thinkpad E14 Gen2 machines out there with settings at factory default and unlocked:
    I want to request two dumps from your machine if you're capable of dumping the firmware from the Winbond 25R256JVEQ flash chip near the screen hinge side.
    One dump with all factory settings.
    Another dump with an administrator password set.
    (Just the first one with factory settings will do nicely too if you don't want to risk it any further. But both will help immensely.)
    The neat thing about it is that one doesn't need to desolder the chip to dump it.
    One can simply solder a few wires to the 8 solder pads for a SOC8 that's unpopulated just adjacent. (It's a pin to pin exact match footprint so Lenovo can use either the SOC8, or the WSON8 package)
    It works the other way around too if the SOC 8 footprint is populated instead. The pads are directly 1 to 1 electrically connected. pin 1 to pin 1, pin 2 to pin 2 and so on. One can probably 3D-print a jig for it to touch wires onto the pads too in order to avoid soldering, if one so desire.
    I'll attach pictures to show you how it can be done. It is how I dumped a locked firmware. I used a CH341A flash reader/writer for this. Works like a treat.
    • SysGhost
      • Mar 2021
      • 12
      • Sweden
      Re: Lenovo ThinkPad E14 Gen2
      Additional information:
      Full name and model:
      ThinkPad E14 Gen2 - Type 20TA-0058MX
        • 21998
        post your EC backup
        • SysGhost
          • Mar 2021
          • 12
          • Sweden
          Originally posted by SMDFlea
          post your EC backup
          I'd need a hint for what type of controller I'm looking for, and maybe if there is an easy way to dump it without the need to desolder it.
          As far as I understand it, this "Embedded Controller" is not a regular flash chip, but a microcontroller of some kind that needs to be completely desoldered to dump?
          There aren't any other flash chips anywhere around the motherboard on either side, except one that sits near the thunderbolt controller and is electrically connected to the thunderbolt controller. Sure I can dump it but I don't think it makes anyone any good. I'll upload it either way.
          • SysGhost
            • Mar 2021
            • 12
            • Sweden
            Okay. I'm making some progress in this. There's very little to no information about this. Or at least I can't find anything at first glance. No one seems to be talking anything about this and everyone assumes everyone knows everything about it.
            I suspect The chip called "IT8227E-256" (QFP128 package) is the controller I'm looking for.
            There seem to be no datasheets on this at all. I have no idea how to dump anything from it.
            The next step would be to desolder it and put it in a jig of some kind to read out the firmware. (But I do suspect it is protected from that type of dumps).
            It has some really fine pitch, which will make it really hard to solder back into place.
            Last edited by SysGhost; 05-21-2021, 07:41 PM. Reason: Thought I found a pdf, but it was a fake. Removed.
              • 21998
              the password seems to be stored in the EC ,https://www.badcaps.net/forum/showthread.php?t=93649 .The EC IT8227E can be read with a special programmer,it has a ribbon cable that connects to the keyboard connector. There`s a few different ones, Vertyanov JIG ,SVOD3 ,SAS (vertyanov clone) .
              • SysGhost
                • Mar 2021
                • 12
                • Sweden
                Thanks! just the information I needed to get further. Now I just have to get my hands on one of those.
                • amara
                  • Oct 2022
                  • 1
                  • UAE
                  Re: Lenovo ThinkPad E14 Gen2 BIOS PASSWORD
                  BIOS/Supervisor password;ples send patch file
                  • Djamalhan
                    • Dec 2021
                    • 78
                    • Узбекистан
                    hi all . was this problem solved?
                    • samsul
                      • Aug 2022
                      • 12
                      • indonesia
                      post your EC backup
                      help me please, Bad SVP Data, Stop Post Task
                      • Vesko356
                        Vesko356 commented
                        Editing a comment
                        https://www.badcaps.net/forum/troubl...before-posting
                        You MUST NOT:
                        • Post a request in multiple threads
                        • Post a request multiple times
                        You MUST:
                        • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                    • Djamalhan
                      • Dec 2021
                      • 78
                      • Узбекистан
                      ORGINAL EC BIOS I need it please.
                    • techrecycle
                      • Jan 2024
                      • 64
                      • england
                      lenovo thinkpad e14 10th gen needs bios password thanks
                      sn: PF-25LYDO
                      • SysGhost
                        • Mar 2021
                        • 12
                        • Sweden
                        In my case, no. Those ribbon cables that are needed to dump the EC are prohibitively extremely expensive. I ended up buying a brand-new laptop instead. That was cheaper.
                        • Tek-jay-el
                          • Jan 2023
                          • 12
                          • Philippines
                          Serial: PF2JTLBD
                          E14 (Type 20RA, 20RB) Laptop (ThinkPad) - Type 20RA​
                          Please help me to unlock my bios here's my uploaded file Thanks in advance.
                          • kalilinux25
                            • Mar 2018
                            • 2089
                            • ZAMBOANGA SIBUGAY
                            Originally posted by Tek-jay-el
                            Serial: PF2JTLBD
                            What is the motherboard code?
                            • Tek-jay-el
                              • Jan 2023
                              • 12
                              • Philippines
                              Board : FE4A0/FE5A0 NM-C421
                              • kalilinux25
                                • Mar 2018
                                • 2089
                                • ZAMBOANGA SIBUGAY
                                try this
                                • Tek-jay-el
                                  • Jan 2023
                                  • 12
                                  • Philippines
                                  try this
                                  I Tried the bios bin, but there was no display after flashing.
                                  • Wakoko
                                    • Mar 2021
                                    • 3
                                    • Philippines
                                    can anyone help me to unlock my lenovo E14 gen1 bios password?
                                    • Grafnus
                                      Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
                                      by Grafnus
                                      Hey there,
                                      first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
                                      So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
                                      Specs:
                                      • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
                                      • CPU, GPU, RAM work fine (not involved in the Problem)
                                      So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
                                      Now I noticed...
                                      08-06-2025, 11:54 AM
                                      Lenovo ThinkPad ThinkPad X1 Fold Gen 1 Ultrabook X Specification for Upgrade or Repair
                                      This specification for the Lenovo ThinkPad ThinkPad X1 Fold Gen 1 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X1 Fold Gen 1 boardview and ThinkPad X1 Fold Gen 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      09-07-2024, 05:20 AM
                                      Lenovo ThinkPad ThinkPad E14 Gen 2 (Intel) Notebook E Specification for Upgrade or Repair
                                      This specification for the Lenovo ThinkPad ThinkPad E14 Gen 2 (Intel) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad E14 Gen 2 (Intel) boardview and ThinkPad E14 Gen 2 (Intel) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                      Lenovo ThinkPad ThinkPad T14 Gen 1 (AMD) Notebook T Specification for Upgrade or Repair
                                      This specification for the Lenovo ThinkPad ThinkPad T14 Gen 1 (AMD) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad T14 Gen 1 (AMD) boardview and ThinkPad T14 Gen 1 (AMD) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                      Lenovo ThinkPad ThinkPad E15 Gen 2 (Intel) Notebook E Specification for Upgrade or Repair
                                      This specification for the Lenovo ThinkPad ThinkPad E15 Gen 2 (Intel) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad E15 Gen 2 (Intel) boardview and ThinkPad E15 Gen 2 (Intel) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                      09-07-2024, 05:00 AM
