ea53-bm/eg52-bm mb 14222-1 no display
    Hi I have a board that no display I tried checking all coils no shorted I tested pin 1 pressing power , no response on my DSO checking the 25mhz crystal display no reading in pin1 and pin2 checking the X1802 pin 1 has a reading .
    1 question if you have no reading on the cyrstal display those the part considered dead?
    I tried chanign the ram but no display its taking 80milliamp
    Re: ea53-bm/eg52-bm mb 14222-1 no display
    Crystal gets power from rtc section
    Rtc means real time clock
    Rtc cell is the voltage provider battery 3.3 volts
    First check rtc cell voltage in cold state
    If ok
    Second check ram section voltage
    If ok
    Then check pltrst# signal and crystal
    To check crystal oscillator remove it from the board
    And it should not beep or connected with each other pins ,just like you check capacitor
      If ok
      If ok
      MY cell is ok. dmrst# has 600miliamp sorry I cant find the pltrst# on my diagram and I cant point it on my actual I dont have boardview
        Dramrst# same as e ram voltage
        DDR3L 1.35
        DDR4 1.2
        You get 0 voltage at dramrst#?
        Confirmed ram section issue or connected part
          Smile Ddr3/ddr4 ram section voltage requirements(working)
          Follow this guide to verify voltage at RAM SECTION
          DDR 3 ram section voltage check list at ram slot
          DDR3 operating voltage VDD (at coil )= 1.5V PINs 75,76 ram slot
          VRef_DQ = 0.75 V at PIN 1
          VTT/Termination voltage= 0.75V PINs 203,204
          VRef_CA. = 0.75V PIN 126
          VDD SPD = 3.3V PIN 199
          SDA data = 3.3V PIN 200
          SCL clock = 3.3V PIN 202
          DRAM_RST# = 1.5V PIN 30
          DDR 3L ram section voltage check list at ram slot
          DDR3L operating voltage VDD (at coil )= 1.35V PINs 75,76 ram slot
          VRef_DQ = 0.67 V at PIN 1
          VTT/Termination voltage= 0.67V PINs 203,204
          VRef_CA. = 0.67V PIN 126
          DRAM_RST# = 1.35V PIN 30
          DDR4 ram section voltage check list at ram slot
          DDR4 operating voltage VDD (at coil )= 1.2V PINs 12,33,75 of ram slot
          VTT/Termination voltage= 0.6V PIN 258
          VRef_CA. = 0.6V PIN 164
          VDD SPD = 3.3V PIN 255
          SDA data = 3.3V PIN 254
          SCL clock = 3.3V PIN 253
          DRAM_RST# = 1.2V PIN 108
          In case of any mistake please notify
            If ok
            If ok
            I tried to test signal on the PLTRST# on pin 19 of U3001
            no good reading not stable
              dramrst# same as e ram voltage
              ddr3l 1.35
              ddr4 1.2
              you get 0 voltage at dramrst#?
              500 milliamp
                i dont have voltage on my PL5001 sir
                  As per sequence diagram at end pages of schematic
                  Imvp pwrgood required for pu5001 and these are last stages but you said drmrst# is 0 which is an early stage
                  Check pin 30 of ram slot , your ram ic is RT8xxx
                  and pu5001 is PCH 1.05v switch ic
                  Follow the power sequence
                    DDR3_DRAM_PWROK_D has 1.3v PM_SLP_S4# has 3.3v ive tested again the dmrst# no voltage readings sir
                      1D35V_S3_PWRGD check
                      Check slp_s4#_d coming out from q3613 at pin 6
                      Check slp_s3#
                        Check slp_s3#
                        meery christmass sir Idont have any reading on pwrgd and s4# also slp_s3#
                          Milliamp???
                          It is voltage ,
                          did you measure in volts
                          If ok
                          Slp_s3# not coming means
                          No rsmrst#, check rsmrst#
                          Need oscilloscope to check crystal ok or not
                            Milliamp???
                            It is voltage ,
                            If ok
                            yes in voltage beore ching the pin 6 i tried to checki form the battery connector if I got votlage .
                              Milliamp???
                              It is voltage ,
                              If ok
                              Sorry sir I forgot to tun it on, SLP_S3# is 3v reading rmst# 3.3v
                                Milliamp???
                                It is voltage ,
                                If ok
                                can you help me again sir
                                  1D35V_S3_PWRGD
                                  Check imvp_pwrgood
                                    1D35V_S3_PWRGD
                                    Check imvp_pwrgood
                                    1D35V_S3_PWRGD - 0v
                                    Check imvp_pwrgood - 2v
                                      Q3613
                                      pm_slp_s4# 3.3v
                                      ddr3_dram_pwrok 0v
                                      pm_slp_s4#_d 0v
                                        Q3612
                                        ddr3_vcca_pwrgd_3p3 - 0v
                                        ddr3_vcca_pwrgd_g 3.3v
                                        ddr3_vcca_pwrgd 0v
