Replacing soc with microcode guidance
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Hi Friends,
    We do face SOC failure in newer motherboards very frequently and the exact SOC may not be lying around. SOC's are difficult to source as reliability is a big question mark besides being expensive as well. So, an alternative can be like getting a SOC from scrap board(You have to be sure that soc is ok). I myself started https://www.badcaps.net/forum/showth...&highlight=SOC this thread but it was inconclusive for various reasons. Many of you must be wondering, which SOC will work on a particular motherboard and do waste a lot of time replacing with an incompatible soc.
    So here is simple guide to make a firm and foolproof decision in finding out which soc will run on a particular mb.
    WARNING: SOC replacement is not an easy job and requires very good bga skills. The soc may bend due to improper profile,bad reballing. Same profile wont work on evry motherboard as some mb may tolerate heat well whereas some others may bend. So be careful.
    SOLUTION: You need only one tool "MC Extractor"(MIcrocode Extractor) to get cpu id from your bios dump.So do the following based on my experience with HP15-LA-A992P Rev 1.0
    01. Download MC Extractor tool. Its attached here for your convenience.
    02. Open the exe file by double clicking on it.
    03.Drag and drop your bios dump on the opened MC Extractor tool.
    04.Press Enter.
    05. Microcode will be displayed on the tool.
    06.Open Intel microcode update guidance pdf file from here
    https://cdn.badcaps-static.com/pdfs/...2baf97fea4.pdf
    07. Look for CPU-id you need and make sure you select "mobile" in Vertical Segment"
    08.Now you know the list of processors which will support on that particular mb.
    My LA-A992P mb had SR1EK as original SOC whereas i succesfully replaced it with SR170 as both have same cpu-id(40651) though there are differences between these two processor like Core Stepping. I've succesfully replaced SOC on many motherboards with these simple steps and hope it will help others as well.
    I'll be happy to answer any queries.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Replacing soc with microcode guidance
    https://www.cpu-world.com/sspec/SR/SR170.html
    https://www.cpu-world.com/sspec/SR/SR1EK.html
    • Stevedb
      Stevedb
      • Feb 2018
      • 624
      • Belgium
      Thank you
      For explaining how you see which microcode cpu you can use. Is very helpful.
      Best regards
      Steve
      • qayyum786
        • Aug 2018
        • 1955
        • INDIA
        @mcplslg123 i really appreciate and respect your hard work and its a huge contribution to the ''BADCAPS FAMILY''
        • piernov
          • Jan 2016
          • 4437
          • France
          In some cases the date can also come into play. If microcode is older than the release date of the CPU, it *might* not be 100% compatible.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Very true. I've not discussed the finer points as it is just a guide. One can even add a microcode to support additional cpu's on many platforms but these things are left out from this guide. Maybe , someone can make a thread about editing microcode in bios dump.
            • kingthink
              • Nov 2022
              • 19
              • China
              hi bro where is the latest code sheet to download
              • kingthink
                • Nov 2022
                • 19
                • China
                You can view the Address and Full size of Microcode with UEFITool, and it will be more convenient to replace Microcode.
                • Vusal
                  Senior Tech
                  • Feb 2016
                  • 41
                  • Azerbaycan
                  Microprocessors CPUID from Intel Microcode Revision Guidance June 14, 2022
                  Update Intel SoC 10th gen CPU
                  • kingthink
                    • Nov 2022
                    • 19
                    • China
                    What tool do you use to add microcode? Do you use winhex directly?
                    • kingthink
                      • Nov 2022
                      • 19
                      • China
