Good day folks. A while back, in a different topic of mine about how I was trying to build my own adjustable power supply from scratch, someone suggested I should just scrap that idea and not bother and just get a pre-made power supply module which would be infinitely better and save me a lot of trouble and so I did: I got myself the DPS5015 of Ali after it was recommended to me, for which I built a nice little enclosure and powered it off a rather beefy UPS transformer. Granted, it was a bit pricey for my taste, but I realise now it was money worth spending because it does everything I need and more and I would have never achieved the same level of functionality and stability with my own attempt at building one.
So now it's time for a new project, bigger, better, stronger
Being very satisfied with the overall performance of these little power supplies, I of course turned to them again as the heart for my new supply and noticed an improved version came out in the meantime, the DPS5020, which can not only take an additional 5A which was already overkill
but also includes a piece of software which allows the board to communicate with an app on a PC or phone so you can view and adjust your values from your PC or device. Now I must admit, although I try to call myself a semi-professional, I AM a sucker for eye-candy like this, so I had to get myself one. Again, expensive ! For my budget at least, especially since I went all-out and got the BT version which I'll probably never use
Actually, the project calls for TWO of them, but I didn't have the necessary funds at the time. It has now arrived and with it sitting on my desk, it's time to start building: same two chunky UPS transformers, two 50a rectifiers, some fuses, two filter caps (more on that later), a ton of wires, enclosure....etc.
I laid down a wiring diagram, although it's very simple: there's two circuits side by side, perfectly identical, to form a dual-output bench supply. This way I can have two completely isolated supplies or I can join their GNDs together to have a common-GND dual-output supply which is handy for testing devices which require more than one power rail (12v-5v for instance). That's the theory at least.
There are some things I still need to work out.
1) Let's start with the very beginning: notice how I wired the two transformers straight to the 230VAC input - should I look for some sort of EMI filtering there ? If so, what should this be ?
2) For C1 and C2 I found some caps on Ali which CLAIM to be 10000uF/80V....is bulk capacitance a generally good idea on the input of the DC-DC modules there or should I look for some inductors as well ?
3) ZD1 and ZD2 - 51v zener diodes. 50v is the maximum input the modules can tolerate. If the 230v input swings too high, the secondary voltage will also increase, possibly past the 50v margin, so supposedly those zeners will become biased and blow F3/F4. Good idea/bad idea ? I fear they may false-trigger often :|
4) feel free to suggest stuff and improve on my design
I'll keep you guys posted along the way with pictures of the build
Cheers and thanks.
