Lenovo 2-in-1s 300/500 Series.Flex 5/Yoga 5 Series BIOS + EC
    • 21692
    Bios + EC 4QCN45WW(V2.09)
    Supported Laptop Systems
    2-in-1s Series: ideapad 2in1-14
    300 Series: 320S-15IKB (Type 80X5), 320S-14IKB (Type 80X4), 320S-15ISK, 320S-14IKB (Type 81BN), 320S-15IKB (Type 81BQ)
    500 Series: 520S-14IKB (Type 80X2), 520S-14IKB (Type 81BL)
    Flex Series: Flex 5-1470 (Type 80XA), Flex 5-1570 (Type 80XB), Flex 5-1470 (Type 81C9), Flex 5-1570 (Type 81CA)
    Yoga Series: Yoga 520-14IKB (Type 80X8), Yoga 520-14IKB (Type 81C8)
    D 220000
    W 610000
  • LeandroTNK
    • Sep 2018
    • 4
    • Brasil
    Re: Lenovo 2-in-1s 300/500 Series.Flex 5/Yoga 5 Series BIOS + EC
    Thank you!!!!
    • ClaytonCho
      • Nov 2018
      • 1
      • South Korea
      Thanks a lot.
        • 21692
        Bios + EC 4QCN49WW(V2.13) .For the same laptops models at post #1 .
        • crowntoy99
          • Oct 2012
          • 267
          • india
          good job
          • jellytot
            • Mar 2015
            • 42
            • Ireland
            Hi SMDflea. I would be grateful if you could patch this damaged bios dump file ? Thanks
              • 21692
              here.
              • jellytot
                • Mar 2015
                • 42
                • Ireland
                Thank You!
                • smartecbh
                  • Nov 2018
                  • 7
                  • Brasil
                  Thanks brother
                  • vougheart
                    • Jul 2020
                    • 65
                    • philippines
                    thank you tested 100%
                    • Gianny14
                      • Jun 2022
                      • 2
                      • Mexico
                      • cnmoli
                        • Jul 2017
                        • 2
                        i hope this is the right place to ask. I have an Ideapad 520-14IKB (81BL) and it is not booting after BIOS update. Can I use the bios file from post #1 to flash the bios chip and what should I do with the ec.bin file? I have bought ch341a programmer and have created a dump file with NeoProgrammer of the faulty bios. BIOS Chip is W25Q64JV.
                        thank you oli
                        • peste
                          • Dec 2016
                          • 13451
                          • ROMANIA
                          thank you oli
                          yes, you can use the bios from post#1.. with the EC bios you do nothing... it only writes the main bios.. but remove the bios chip from the motherboard before writing... you don't use the clip gives errors... if you don't have adapror for bios chips stick the chip on the programmer..
                          https://www.youtube.com/watch?v=DWWigscuQDY
                          • cnmoli
                            • Jul 2017
                            • 2
                            thank you, it worked. But I did use a clip, so didn't have to solder the bios chip from the motherboard.
                            • osman68i
                              • May 2015
                              • 350
                              • The Netherlands
                              Lenovo Flex 5-1570 la-e541p Bios need
                              I need bios for Lenovo Flex 15 1570 la-e541p Rev 2A
                              laptop model
                              Flex 15-1570
                              81CA
                              LA-E541p Rev 2A
                              Nvidia GPU
                              serial MP1EGZ2F
                              original bios is attached
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12278
                                Re: Lenovo Flex 15 1570 la-e541p Bios need
                                laptop model
                                Flex 15-1570
                                81CA
                                LA-E541p Rev 2A
                                Nvidia GPU
                                serial MP1EGZ2F
                                Flex 5-1570 (Type 81CA) Laptop (Lenovo) - Type 81CA
                                • osman68i
                                  • May 2015
                                  • 350
                                  • The Netherlands
                                  thank you,
                                  no video. I think gpu is defect.
                                  • joemateo
                                    • Jul 2016
                                    • 6
                                    • ecuador
                                    thanks friend
                                    • piotrux
                                      • May 2016
                                      • 11
                                      • poland
                                      Hi, I need a BIOS dump with correct DMI data for "bottom information". The laptop had shorted KBC, after replacing and starting the laptop the DMI information disappeared, and the keyboard didn't work either. There were no visible soldering marks on the BIOS chip (it seems that no one had modified the contents before). I am attaching a dump with the laptop working correctly, but no DMI, and the original, I would like to supplement it with correct data.
                                      Lenovo 320S-14IKB 80X4
                                      CIUYA/YB/SA/SD LA-E541P Rev 1.0
                                      KBC: NPCE388NB0DX
                                      MTM: 80X400F9PB
                                      SN: MP1BUFCG​
                                      • peste
                                        • Dec 2016
                                        • 13451
                                        • ROMANIA
                                        KBC: NPCE388NB0DX
                                        MTM: 80X400F9PB
                                        SN: MP1BUFCG
                                        post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                          Lenovo ThinkPad Yoga 370 Hybrid (2-in-1) Yoga Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad Yoga 370 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 370 boardview and Yoga 370 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 08:10 AM
                                          Lenovo ThinkPad Yoga 260 Ultrabook Yoga Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad Yoga 260 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 260 boardview and Yoga 260 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                          09-06-2024, 05:33 AM
                                          Lenovo Yoga Yoga 6 13ALC7 Notebook 700 Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 05:00 AM
