toshiba satellite c55-b
  • mohammed aram
    • Apr 2015
    • 73
    • egypt
    hi everybody
    i have aboard of toshiba da0blimb6f0
    there is no schematics for this
    and the lap power dead
    there is 5 v and 3.3 v
    any suggesion??
  • bachir2004
    • Feb 2015
    • 437
    • maroc
    Re: toshiba satellite c55-b
    is this your motherboard?
    • piernov
      • Jan 2016
      • 4435
      • France
      No his moterboard is Quanta BLI, schematics not available.
      Nothing after pressing power button? 3.3V on power switch?
      Check resistance of R391 (0ohm), and its resistance to ground (on both sides).
      • mohammed aram
        • Apr 2015
        • 73
        • egypt
        nothing after power button
        3.3 found on power button
        resistance of R391 2.8k from both side
        • mohammed aram
          • Apr 2015
          • 73
          • egypt
          no i have diffrenent board
          thanks for reply
          • piernov
            • Jan 2016
            • 4435
            • France
            KBC is Nuvoton NPCE985LA0DX?
            Voltage on pin 102(AVCC), 115(VCC) of KBC?
            Voltage on pin 95(NBSWON#), 91(DNBSWON#), 75(RSMRST#), 73(SUSC#), 94(SUSB#), 22(SUSON#) after pressing power button?
            • mohammed aram
              • Apr 2015
              • 73
              • egypt
              pin 102 =3.3 volt
              pin 115=3.3
              pin95 3.3 volt go to 0 when pressing button and come back to 3.3 volt
              pin 91 after pressing power button risisng 3.3 volt
              pin rsmrst after pressing no response 0 volt
              pin 73 have 3.3 volt and no changes after pressing
              pin 94 have 0 volt and no changes after pressing
              pin 22 have 0 volt and no changes
              • mohammed aram
                • Apr 2015
                • 73
                • egypt
                i want to know which bios chip of the kbc u u17 or u18
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  Yep could be BIOS issue.
                  BIOS is U18 (I think). Contains both the main BIOS and the EC ROM.
                  Try to flash it with a known good dump (I don't have it, sorry).
                  • mohammed aram
                    • Apr 2015
                    • 73
                    • egypt
                    i reflash the bios and not woking
                    the 8th leg of u 18 have no 3.3 volt before i press power button
                    is this normal??
                    any suggesion??
                    • piernov
                      • Jan 2016
                      • 4435
                      • France
                      What do you get on KBC pin 26(S5_ON)?
                      It depends on the motherboard and without schematics it is hard to tell. 3.3V for U18 may come from +3.3V_S5, which may appear only after pressing power button (if everything work correctly).
                      Or it may come from the always on 3.3V but you said it is present so BIOS chip should receive power if that's the case.
                      • mohammed aram
                        • Apr 2015
                        • 73
                        • egypt
                        first i would like to thank you very much for your help
                        second iam confused about this
                        i will check kbc pin 26 tomorrow but i think it will be present because the s5 voltage 5 and 3.3 present on the coils of power chip
                        The puzzling thing if the u18 chip is the bios chip of the kbc and the pch integrated with cpu on this platform i should find 3.3 volt on the 8th leg of u18 on s5 state to make kbc do it,s job
                        give me some information about this please
                        • piernov
                          • Jan 2016
                          • 4435
                          • France
                          Yep but laptop power rail sequences are usually very confusing, they're different from motherboards to motherboards. S5 state doesn't mean "always on" too, sometimes it is always on, sometimes it is switched from the always on rail with a MOSFET, sometimes it is created by another DC-DC converter. The two last options are usually controlled by the S5_ON signal.
                          Now, the BIOS chip can be powered from the always on rail, the S5 rail, the S3 rail…
                          Sometimes the datasheet of the KBC can help, but this one is not available.
                          Without schematics (and power sequence diagram), it is hard to tell. You will have to find out what the VDD pin of BIOS chip is connected to.
                          Maybe someone else have more information/experience on this?
                          • mohammed aram
                            • Apr 2015
                            • 73
                            • egypt
                            KBC pin 26(S5_ON) no voltage after pressing and before pressing power button
                            • piernov
                              • Jan 2016
                              • 4435
                              • France
                              I guess I don't have the right pinout for the KBC then…
                              Could you try to find the 5V/3.3V regulator on the board? It may be an RT8223P in 24 pins QFN package with markings (? being some letter/number for datecode):
                              20 ??
                              And report the voltages on pin 8, 11, 13, 17, 18, 20.
                              Try to use your multimeter in continuity mode to check where the BIOS VDD pin is connected.
                              • mohammed aram
                                • Apr 2015
                                • 73
                                • egypt
                                20 ??
                                power chip marked with
                                3G=1f c16
                                • mohammed aram
                                  • Apr 2015
                                  • 73
                                  • egypt
                                  it seemes to be RT6575A
                                  • piernov
                                    • Jan 2016
                                    • 4435
                                    • France
                                    Ok great, in that case you get 3.3V on pin 3 and pin 8 (or 18). And you get 5V on pin 13 and pin 18 (or 8)? Do you have continuity between any of those pins and the BIOS VDD pin?
                                    Check if the BIOS chip is 3.3V and not 1.8V too.
                                    • mohammed aram
                                      • Apr 2015
                                      • 73
                                      • egypt
                                      pin 3 =3.3 ok
                                      pin 8 oscillate on the osclliscope
                                      pin 13 5 volt ok
                                      pin 18 oscillate on the osclliscope
                                      it seems every thing is ok
                                      bios chip is 25b64bsig and this is 3.3 volt chip not 1.8
                                      • pete_the_geek
                                        • Jan 2011
                                        • 20
                                        I have the exact same problem with a Toshiba L50B same BLI motherboard.
                                        Both 3v3 and 5v present, also CPU heats up, no action on Power button press, no 3v3 on pin 8 SPI 25B64SIG.
                                        Did anyone get to the bottom of this?
                                          Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 06:10 AM
                                          Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 05:40 AM
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite Satellite P50t-C-111 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Satellite P50t-C-111 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite P50t-C-111 boardview and Satellite P50t-C-111 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 08:10 PM
