Fix Vestels based on 17MB62 stuck on boot up
    I got a 17MB62-2.5 Vestel in for a fiddle from a friend (22", 1080p Toshiba). TV stuck in standby with blinking LED.
    Getting a console is easy with these devices. Simply connect SCART port pin 12 to a UART receiver and pin 10 to UART transmit. Pin 13 is ground. You will need a device that can accept 3.3V UART (so a normal COM port will probably not work.) Parameters are 115200, 8N1 serial.
    Upon doing this I was greeted with a long boot dump followed by:
    Code:
    ******Application Started*****
    pthread_mutex_init
    CHIP_InitISR
    mem_type: 0, phy_addr = 0x75c1000, start_addr = 0x42082000, size = 6291456
    mem_type: 1, phy_addr = 0x7bc1000, start_addr = 0x32682000, size = 0
    ******* ICE_LoadProfileData - Enter
    Load profile /conf/mb62_hwprofile.bin
    ******* ICE_LoadProfileData - Exit
    Load profile /conf/mb62_swprofile.bin
    PM Bank mapping success. Base=[4b306000], Size=[225600]
    NonPM Bank mapping success. Base=[4b52c000], Size=[25600]
    Flash Bank0 mapping success. Base=[4b552000], Size=[4000000]
    **** ICE_HardwareInit ****
    FROST_DebugStartConsole !
    Terminal: vt102
    terminal ready
    Load profile /conf/mb62_langprofile.bin
    #*### Console Started ###
    Load tune file
    Try loading bin panel file
    Read : 15084 target: 15084
    Segmentation fault
    starting pid 190, tty '': '/bin/echo /bin/Xjys > /proc/sys/kernel/hotplug'
    Please press Enter to activate this console.
    The "segmentation fault" is the problem - the main app is crashing for one reason or another. Pressing Enter then drops the TV down to a console where commands can be executed. The TV has a very limited shell with busybox on Linux 2.6.
    I can see the problem appears to occur around the "load panel bin file", so I did a little diving.
    If I try to execute the main app /vendor/aurora.elf, the same problem occurs. In /vendor there is a panel.bin file; this is full of binary data. I decided to rename this to see what would happen, and surprisingly enough it appears that the TV recreates this file if there is a problem with it (this line is printed where the "segmentation fault" would have occurred):
    Code:
    Can not load bin...Try parsing (0 15084)
    After this, the TV booted normally and seems to work now. I'll have to check the rest of the operation to see what's up with it.
    The only problem I have, is that I'm locked out of the console now. I'll have to get it to load an image from the Toshiba website and modify it to drop me to a console again.
  • AJ847.63e
    Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
    by AJ847.63e
    Hi Folks,
    Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
    I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
    The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
    05-06-2025, 10:37 PM
    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-12-2024, 02:20 PM
    HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
    09-06-2024, 10:56 AM
    HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
    HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
