LG 60PZ950 purple and green color artifacts
  • brewman
    • Nov 2013
    • 14
    The color artifacts seems to change flickering at times and steady other times on background and faces. After tv warms up it seems to get worse. I've checked external input conntections and have tried different HDMI inputs. Problem persists.
    Purple on menu bar picure and green with some blues on garage of other picture.
    I've also noticed a flickering of brightness of the green field when watching football games. Other times when a different scene comes on the problem goes away.
    Not sure if related but sound quality at times sounds distorted.
    Any ideas?
    Re: LG 60PZ950 purple and green color artifacts
    Looks like one of the main voltages (Vs, -Vy or Vsc) could be wrong, possibly drifted out. To adjust, you need to have a digital multimeter and the back of the set off.
    • brewman
      • Nov 2013
      • 14
      Thanks for the quick reply.
      I set the voltages dead on. Prior voltage close within 1 volt.
      Now
      Vs = 201
      Va = 55
      Vy = 180
      VSC = 150
      No noticable difference.
      • brewman
        • Nov 2013
        • 14
        BTW. adjustments made while in white screen mode.
          OK, can you post a picture of the whole back chassis, showing all the boards?
          • brewman
            • Nov 2013
            • 14
            back of 60PZ950
              Bottom left board here
              https://www.badcaps.net/forum/attach...8&d=1385834586
              Do you see two points marked EXT AUTO GEN?
              • brewman
                • Nov 2013
                • 14
                No. I looked at all visable boards and couldn't find.
                  Can you post a close up picture of the board I referenced. That position should be marked there somewhere.
                  • brewman
                    • Nov 2013
                    • 14
                    60PZ950 control board
                      OK, it's not marked on this board, but the blue holes should be jumpered. Then the red connector should be unplugged. TV should then be plugged in. You should get test patterns. Are they poor?
                      • brewman
                        • Nov 2013
                        • 14
                        Sorry about all the reflections. Best I could do with light conditions.
                        Artifacts apparent here as well. Test was moving and changing colors took pictures of artifacts on white screen.
                        Noticed IR at bottom of screen.
                          OK, top right board:
                          Can you see any points marked "Vzbias"? What do you measure across them?
                          • brewman
                            • Nov 2013
                            • 14
                            VZB = 120
                            I set it to 110.
                            Rechecked other settings. They are the same.
                            Vs = 201
                            Va = 55
                            Vy = 180
                            VSC = 150
                              OK, on the Y-sustain, you should have some potentiometers (adjustments, like on the PSU for Vs and Va) marked SET UP or RAMP UP, and SET DN or RAMP DN. Unfortunately you can't measure the voltage for these settings, so it is trial and error. Mark the original factory setting (a marker pen works.) Then try SET DN. Try to reduce the clouding. If that fails, try SET UP.
                              • brewman
                                • Nov 2013
                                • 14
                                Tried tweeking set_up and set_dn pots made a slight difference but problem remained. Returned those to original setting. However, I recheck voltages on other test points all were fine except Vy = 166 Set it back to label setting of Vy = 178. (Don't ask me where I got the Vy = 180 on earlier post.)
                                • brewman
                                  • Nov 2013
                                  • 14
                                  I have the tv working again without the artifacts.
                                  The upper right hand board, VZB board ( z-bias?) has 3 copper coils that appeared to get very hot discoloring the pcb. I took the board off and observed the solder joints on the back, noted on attachment circled in red. Resoldered the joints now circled green. Picture is now back to normal.
                                    If Vzb is good, there is nothing further to suggest but try adjusting voltages for best image. Perhaps panel has problem and firmware update can fix it, which was an issue with early LG plasmas.
                                    • brewman
                                      • Nov 2013
                                      • 14
                                      Tom66 tv is fixed. Loose solder joints were the problem.
                                        That's good to hear but I can't see how those caused that fault. They are ERC inductors... Anyway, enjoy the TV!
