IPTV set top box repair question
  • Swervin
    • Oct 2011
    • 4
    Hello everyone, I work for a company that provides IPTV service and we have several set top boxes (50+) that share a common defect with a capacitor manufactured by Teapo. The capacitor is a 470uF 25v SY series. I believe it is the 10x12.5mm one listed in this datasheet: http://www.teapo.com.tw/ftp/pdf/SY.pdf .
    I was wondering if the Panasonic FR series would be considered an appropriate replacement for these. Specifically I had these in mind: http://search.digikey.com/scripts/Dk...name=P14419-ND . I've recapped two of the set top boxes with these, and they seem to work good, but I want a second opinion, and after reading the forums for a couple days this seemed like the most knowledgeable place to ask.
  • mariushm
    • May 2011
    • 3799
    Re: IPTV set top box repair question
    Yes, in my opinion it's good.
    If you have room height wise, you can go for something even better (from good specs to lower specs, but all above the teapo specs):
    http://search.digikey.com/scripts/Dk...me=565-1694-ND 20mm tall
    http://search.digikey.com/scripts/Dk...name=P12388-ND 16 mm tall
    http://search.digikey.com/scripts/Dk...name=P14441-ND 16mm
    http://search.digikey.com/scripts/Dk...me=565-1677-ND 16mm
    http://search.digikey.com/scripts/Dk...me=493-1582-ND 20mm
    Some of them are rated for 35v, which is not bad - going up in voltage is OK.
    • VaNS
      • Oct 2010
      • 9
      I'm still kind of new here but from what I see they both spec out the same pretty much. But in my opinion I would actually go up in voltage maybe 35V that is if it seems to be a reoccurring issue in similar devices. From what I know it's normally recommended.
      • Swervin
        • Oct 2011
        • 4
        Thanks for the help guys. We're not sure why they fail, could be heat, they're mounted a little less than a cm from the processor's heat sink. I measured voltage across it when the box was running, and it measured 3.334VDC.
        It'd odd, because there's quite a few of these types of capacitors on the board, but it's consistently this one failing, never the others. Could be a design flaw too I guess.
        • mariushm
          • May 2011
          • 3799
          Go for the taller ones then, even if they're rated for higher voltage - looks like you have the room.
          Should have longer endurance and since they're more common - they're cheaper when you buy them in volume.
          I do want to point out that the capacitors on the top of the list of links I posted have much lower impedance, around 25 mOhm compared to Teapo's 60-70 mOhm range.
          Lower impedance is almost always better but in some rare cases, it's possible to have issues - I doubt this is the kind of complex circuit where everything is so fine tuned that lower impedance would cause issues but someone more experienced than me should give some feedback.
          • BryGuy460
            • Dec 2011
            • 1
            Wow, looks like a mess. I have never had a problem with the IPTV Pod, been working great straight out of the box.
            • piernov
              NVidia bumpgate
              by piernov
              Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
              Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
              May complete this post at a later date with more details.
              Basically issue is a combination of thermal dissipation of the chip with hotspot,...
              03-27-2021, 10:34 AM
            • vulubalulu
              Dell U2718Q, horizontal lines. second opinion welcome
              by vulubalulu
              I have never seen an issue such as this one. horizontal lines across the monitor in a consistent manner. I am really interested to get to the bottom of this and I'd value any input from the community.
              There are three separate PCB parts attached to each other. They function as SMPS, backlight driver and main board.
              I checked the all three blue PCBs: SMPS outputs 19V, PWM controller + mosfets without anomalies, main board has 3V, 5V, 10.5V and 19V present. Crystals output the right clockspeed. This is to be expected as the monitor turns on.
              I haven't explored at the green PCB (TCON...
              08-14-2024, 03:08 PM
            • BOSCHNJAK
              by BOSCHNJAK
              ABOUT ME INTRODUCTION FILE
              2
              024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
              2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
              2022 BEV, PROJECT ?
              2021 BEV, PROJECT ?
              2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
              2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
              12-28-2023, 02:09 PM
            • unnu
              please tell me your opinion on this situation
              by unnu
              i was a proud owner of a new lenovo y560 laptop
              for me it was a very new experience to use a laptop . i had used only desktop PC many times. i enjoyed playing games on my laptop very much. This pleasure lasted only till the day there was a electric power cut followed by a power surge at my home and while i was playing a game (crysis 2) . when the power cut happened the laptop Operating System went automatically to power saving mode...so the heatsink cooling fan stopped spinning and then ( a few seconds later ) as soon as the electric supply resumed and power surge happened the laptop shifted...
              12-29-2020, 08:44 AM
            • peku
              HP Omen 17-w104no dead PCH? Second opinion
              by peku
              First some laptop info:
              Model: HP Omen 17-w104no
              Motherboard: Quanta G38D
              CPU: Core i7 I7-6700HQ (I think?)
              GPU: nVidia GTX 1070
              What happened: plugged in an old smartwatch for charging/syncing after years of no use, after a while computer just shut down, leaving a little white light at the power button. Pressing power after that, nothing happens. After opening up case and disconnecting/connecting battery, not even that white light appears, no light on the charging connector either.
              I've tried diagnosing with a multi-meter...
              01-25-2022, 07:47 AM
