Thinkpad Edge E540 missing PM_SLP_S5# and VM_PWRON
  • maneatingmonkey
    • Feb 2020
    • 36
    Hi, I'm seeking the knowledge of repair wizards familiar with Thinkpad power on sequences.
    The symptoms are that when the power button is pressed, the red light comes on, but there is no other activity.
    The +3VALW and +5VALW rails are present, but none of the subsequent voltage come up. No shorts on inductors or anything obvious like that. EC_RSMRST#, PBTN_OUT# and +RTCVCC are all present, but there is no PM_SLP_S5# or later signals.
    I also do not get a VM_PWRON signal. I believe this is needed to enable initial power to the BIOS chips, which are not getting any power ATM. I found the attached sequence diagram from another Thinkpad, but there is no VM_PWRON on that model.
    Does anyone know if VM_PWRON is supposed to come on before or after PM_SLP_S5#? Or should this signal be present before I even press the power button?
    [Mod. Edit-Vesko356] Schematic and boardwiew: https://www.badcaps.net/forum/showth...53#post1235553
    Last edited by Vesko356; 05-02-2023, 10:19 AM. Reason: Attached schematic and boardview removed and replaced with link.
  • mon2
    • Dec 2019
    • 14315
    Re: Thinkpad Edge E540 missing PM_SLP_S5# and VM_PWRON
    Remove all power. Meter in resistance mode.
    What is the resistance to ground of VM_PWRON ?
    Meter in DIODE mode.
    Red meter probe, yes red to ground.
    Black meter probe to VM_PWRON.
    What is the reading?
    • maneatingmonkey
      • Feb 2020
      • 36
      Resistance: 91kΩ (black on ground)
      Diode mode: 700 on the dot (red on ground).
      • mon2
        • Dec 2019
        • 14315
        So there is no short but output is not correct.
        The EC at ue1 has an internal 8051 style micro that requires valid firmware to boot. Perhaps the firmware is corrupted. Not a pro at the EC area so wait for other comments. I think you need an external tool to reflash the firmware. That may fix this fault.
        Another idea is to review the parts this line enables to see if you can manually enable them. However this takes away the proper sequencing of the power rails.
        The downstream devices are load switches / buck regulators that enable by this signal.
        Do see that there are some 0 ohms resistor / solder blobs that could be removed and then the EN can be tied to the 3VALW rail to enable.
        Ideally you want the EC to enable these parts but the above is an idea for testing.
        • maneatingmonkey
          • Feb 2020
          • 36
          If I tie VM_PWRON to 3V then the downstream devices (SPI chips, +1.05VMP rail) get power as expected, but that's it. However, if I instead tie PM_SLP_S5# to 3V, then the laptop actually POSTs when I press the power button.
          PM_SLP_S5# is sent from the PCH to the EC.
          Question 1: How can I isolate if the problem is with the PCH or further upstream? What input signals does the PCH need to assert PM_SLP_S5#?
          Question 2: How bad of a workaround is it to leave PM_SLP_S5# connected to 3VALW?
          • Maxpower3
            Brand name and Model Type for Lenovo error 2202 product name is invalid
            by Maxpower3
            Info for error 2202 LenovoThinkPad models and type
            Extract from ThinkPad Maintenance Utilities Configuration File
            plnsrv.ini Version 1.01
            Some information that may be useful
            There must also be missing models, add them to the list if you know of any.
            Code:
            brand name
            20B1=ThinkPad Edge E445
            20B2=ThinkPad Edge E545
            20BC=ThinkPad Edge E145
            20BM=ThinkPad X140e
            20BL=ThinkPad X140e
            20A3=ThinkPad X230s
            20AH=ThinkPad X230s
            20AK=ThinkPad X240s
            20AJ=ThinkPad X240s
            02-21-2024, 10:27 AM
            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
            09-06-2024, 11:40 AM
