Lenovo Ideapad 3-15ITL6 NM-D472
  • tbgaming
    • Mar 2021
    • 13
    • canada
    Hey all, I have an Ideapad 3 15ITL6 in house and theres no backlight, I changed the LCD hopeing but same outcome. Ive run the board around my microscope a few times and cannot seem to find the backlight fuse if anyone knows its location or has a schematic for the NM-D472 REV:2.0
  • TurboAnimal
    • Jan 2023
    • 7
    • Mexico
    Re: Lenovo Ideapad 3-15ITL6 NM-D472
    Hello. I suffer from the same problem as the partner, tbgaming. My IdeaPad 3 15ITL6 NHS460 HS560 HS760 NM-D471 REV 2.0 does not send light to the screen. I suspect the backlight fuse. I can't locate it. I don't have the schematic. If someone shares the schematic or at least helps me locate where the backlight fuse is, I'll check with the multimeter if it's working or if it's blown. Please someone help.
    • Bonzas
      • 472
      • Indonesia
      Send clear picture from your board both top and bottom near EDP and DC connector
      Here's is fuse backlight
      • TurboAnimal
        • Jan 2023
        • 7
        • Mexico
        First of all, thank you for taking the time to answer. Well, I have taken photos of both sides of the mother: near the lcd connector and behind the lcd connector. Now, and forgive my lack of experience, but how should I measure the circuit that may be damaged and perhaps should be replaced? What I know is measured with the multimeter in V, 20, grounding in some area of the motherboard and on the other side in the circuit, fuse, am I correct or am I ignoring something else? All the help you give me will be useful. On the other hand, I have investigated and seen video where on the one hand, the fuse is replaced or on the other hand a bridge is made. What do you recommend me?
        • Bonzas
          • 472
          • Indonesia
          Here's is schematic. If you want learn, try to make sure all voltages regarding on schematic
          • TurboAnimal
            • Jan 2023
            • 7
            • Mexico
            Thank you very much.
            • TurboAnimal
              • Jan 2023
              • 7
              • Mexico
              There is a small detail, the document that you have given me for NM-471 is Rev 1.0 and my mother is Rev 2.0. According to a video where I was explained how to find the fuse backlight circuit, according to the schematic I look for "DISPOFF_N" but I can't find the circuit according to the schematic. Maybe it's because the document you gave me is Rev 1.0 and my mother is Rev 2.0, there are changes in the mother and names of the circuits. Do you or someone have the schematic of NM-D471 Rev 2.0?
              • AL._.EX
                • Dec 2022
                • 894
                • Belarus
                According to the diagram, there is a resistor R121 0 Om, which works as a fuse.
                • TurboAnimal
                  • Jan 2023
                  • 7
                  • Mexico
                  https://www.badcaps.net/forum/attach...2&d=1675462628
                  https://www.badcaps.net/forum/attach...1&d=1675462628
                  Can you tell me which mother model you are talking about and indicate according to the photo? Well, in the mother that I am looking for a solution, there is no resistance with the name R121 or C133. Look at the real photos I uploaded of the plate. That's why I think that to locate the mother I have I need the NM-D471 Rev 2.0 schematic, which by the way I can't find anywhere.
                  • Alexon2023
                    • Feb 2023
                    • 1
                    • Ukraine
                    • devonoved
                      • Sep 2021
                      • 2
                      • jamaica
                      Thanks Gents. Had this issue recently. ideapad 3-15ITL6 Blown display back light and blown Camera/Mic after replacing a part. Had to bridge the fuses FV1 (Backlight) and FI101 (Camera power) under the Display connector on the mainboard (the fuses were too small to replace for me at least.) up and running with backlight and camera ok again for now.
                      • InoveInformatica
                        • Sep 2023
                        • 1
                        • Brazil
                        It's a white fuse with some black markings underneath the flex on the opposite side of the board.
                        • sasser
                          • Dec 2012
                          • 365
                          • Malaysia
                          hi are this issue is solve. i have the same problem. from schematic i got short on CV6 which is brown caps around FV1. al ready replace but still dimmed. im also measure FV1 and i got 20v in 1 side and from site 2 i got 9-11v
                          • Ander79
                            • Mar 2021
                            • 1
                            • Colombia
                            Thank you very much, you just saved my life, a hug from Colombia.
                            • greypally
                              • May 2013
                              • 23
                              Awesomesauce!! Thanks a million!!
                              • wood super
                                • May 2024
                                • 1
                                • Bogotá
                                Thanks for the contributions, they have also saved my life. Greetings from Colombia.
                                • servet alaçam
                                  • Jun 2024
                                  • 1
                                  • Turkey
                                  Hello friends. What will be the value of the capacitor? It looks like a short circuit, but it can't be for insurance purposes, right?
                                  • rob.cab
                                    • Jun 2024
                                    • 2
                                    • chile
                                    thanks a lot for the schematics, this monday ill try to repair a no power issue
                                    • jellyroll
                                      • Sep 2024
                                      • 1
                                      • 대한민국
                                      I am sure your method is correct. Thank you.
                                      Should I replace the fuse? Should I replace the capacitor?
                                      If it is a fuse, is this correct? 0R 0805 5%
                                      What specification is correct for the capacitor?​
                                      • chakey
                                        • Jan 2009
                                        • 6
                                        • Montenegro
                                        Lenovo ideapad 3 15ITL6, no picture on LCD screen but there is a picture on external HDMI monitor.
                                        Like on the schematic fuse FV1 was blown because capacitor CV6 was shorted. Changed capacitor with 10uF capacitor but I didn't have it in same size so little bigger one, and fuse replaced by wire link.
                                        Everything works fine now.
                                        Thanks.
                                          Lenovo IdeaPad IdeaPad 3 15ITL6 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 15ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15ITL6 boardview and IdeaPad 3 15ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          Lenovo IdeaPad 3 15ITL6 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 3 15ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ITL6 boardview and 3 15ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                          09-07-2024, 06:31 AM
