Boardview / Schematics of Lenovo Thinkpad E14 NM-C771
  • BioMenace
    • Oct 2022
    • 3
    • ar
    Hi all. i have One of these Lenovo thinkpad E14 laptops that come with a ryzen cpu, but memtest gives thousands of errors. Because of this it's imposible to install Windows as install fails.
    Sadly Lenovo built it with ram soldered to motherboard + 1 empty sodimm slot for ram expansion.
    So I'm curious of what can be done with it, perhaps with boardview there are tips on how to disable onboard ram, wich would be great , i could install a sodimm ram and bypass the soldered ram.
    Another thing that could be done is to patch bios, but i have no idea on that.
    so im looking for Boardview of
    Thinkpad E14 Gen 2
    NM-C771 REV 0.2
    BoardView Pdf, Schematics
    i noticed another site has those files but they charge a lot of $.
    thanks
  • BioMenace
    • Oct 2022
    • 3
    • ar
    Re: Boardview / Schematics of Lenovo Thinkpad E14 NM-C771
    i was able to get a big schematic file about 6 megabyte pdf
    but still no boardview , i don´t think that file works for checking if there is a resistor that can be changed in order to turn off the onboard ram.
    if im wrong please let me know
    i am attaching the file here, just in case someone wants to take a look
    it contains a lot of info for thinkpad E14 gen2 (AMD Ryzen)
    • s9456
      • Oct 2022
      • 3
      • china
      This boardview has no component codes.
      • Bustersat
        • Mar 2023
        • 3
        GE420/GE520 NM-C771 Schematics needed
        Looking to find the LCD backlight fuse on this Lenovo Board. Any help out there?
        • Bustersat
          • Mar 2023
          • 3
          Is there anyway to search these files? Sorry. new to repairs. I have downloaded openboard and boardviewer, but neither will open these PDF's interactively. Can not find any other source of schematic files. Thanks!
          • sellit
            • Jun 2017
            • 105
            • Latvia
Name:	Memory straps NM-C771.jpg
            Successfully disabled built-in memory, Set first 3 Board_ID to 111
            • grazeholder
              • Apr 2017
              • 14
              • Greece
              Hello, i have an E15 Lenovo with bad onboard memory and the boards look like almost the same.
              Can you please explain what you mean by change board id to 111 ?
              I have already removed soldered ram and try to figure out the next step.
              Also resistors on the board they are not labeled so if you could show me some photos or explain what i have to change i would appreciate it.
              • Vesko356
                Vesko356 commented
                Editing a comment
                What's the motherboard number, same NM-C771 or different?
            • grazeholder
              • Apr 2017
              • 14
              • Greece
              Vesko356 Motherboard number is: GE420/GE520 NM-C771 REV 1.0 with the AMD APU
              Also are the boardview and scematics available? it looks like they only sell them on various sites.
                SMDFlea commented
                Editing a comment
                Post 2 schematics,open with pdf viewer. Post 6 boardview ,open with BoardViewer or FlexBV free
            • sellit
              • Jun 2017
              • 105
              • Latvia
              Check boardviewer file, to set ID 111, move resistor RC111 to RC110, RC113 to RC112, RC115 to RC114. If isn't already, in my case RC110 was already there.
              • xloomx
                • Oct 2020
                • 51
                • Argentina
                Thanks!
