Lenovo Thinkpad E570 (Rev. 3.0) - BIOS Dump ?
  • Acnologia
    • Dec 2016
    • 421
    • Poland
    Hello to all !
    I have in my hands a
    Lenovo Thinkpad E570 ,that turns on ,passes all extended tests (after stress) BUT.
    It hungs up , as soon as i try to install any Windows 10 , install (USB) brand new, different ones, as soon as it loads the (turning cycle) , it crashes and shows.
    ACPI ERROR BIOS
    Tried to reset it , default settings ,tried everything, but everytime shows a different BIOS ERROR.
    So....
    (I have also tried some dumps i found around here on site but to either of those, it doesn't even boot up).
    So ....
    I need a dump for
    E570 REV. 3.0
    I7 7500U + NVIDIA GPU.
    Thanks in advance.
  • pooya_pm
    • Jan 2021
    • 254
    • iraq
    Re: Lenovo Thinkpad E570 (Rev. 3.0) - BIOS Dump ?
    Board number photo?
    • hoaca388
      Badcaps
      • Jan 2022
      • 11773
      • Acnologia
        • Dec 2016
        • 421
        • Poland
        Originally posted by pooya_pm
        Board number photo?
        as requested.
        The reason you provide me with that link ? Any wrong , with my thread ? (Moderator should check then )
        • hoaca388
          Badcaps
          • Jan 2022
          • 11773
          Originally posted by AccountSaver
          as requested.
          Post your original corrupt bios file and serial number here.
          • Acnologia
            • Dec 2016
            • 421
            • Poland
            Here you go
            • hoaca388
              Badcaps
              • Jan 2022
              • 11773
              Here you go
              Try
              • Acnologia
                • Dec 2016
                • 421
                • Poland
                Try
                Really strange behaviour.
                Laptop got stressed again in the extended test, and passed all diagnostics just fine, even 180minutes stress of RAM (Brand new)
                Tried SATA, tried M.2 ,tried New Windows 10 USB stick (which just formated another computer).
                But again the same behaviour occurs.
                Laptop as soon as you try to boot from USB and loads the Windows logo, it freezes and restarts... and then shows ACPI BIOS error.
                What the hell?
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11773
                  Try a new bios chip.
                  Can you " Set the ACPI mode to S1 in BIOS " ?
                  https://windowsreport.com/acpi_bios_error-windows-10/
                  • Acnologia
                    • Dec 2016
                    • 421
                    • Poland
                    easy.
                    I have plenty of Winbond brand new chips un-written.
                    So i will try a new one,with your file and cross my fingers.
                    Because it's really strange in my mind, a stressed tested laptop ,to hang up as soon as you get into the windows 10 , load screen for the format.
                    I even tried an SSD/M.2 with pre-installed windows 10 fresh installed , to boot it from ,just to see if evertyhing will go fine, but again it showed the ACPI BIOS error.
                    Will let you know within the day.
                    • Acnologia
                      • Dec 2016
                      • 421
                      • Poland
                      Done.
                      Nothing again ,same error . ACPI BIOS ERROR.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11773
                        • Acnologia
                          • Dec 2016
                          • 421
                          • Poland
                          The only similar option like that was the "Power management the CPU" and Disabled it, again the same.
                          There is no "ACPI" clear option in the BIOS Settings.
                            • 20966
                            https://www.badcaps.net/forum/showthread.php?p=1034021
                            The same thing happens to the E530,E330 they have a non acpi compliant bios.
                            • Acnologia
                              • Dec 2016
                              • 421
                              • Poland
                              Which means?
                              So we are stuck ?
                              It doesn't have battery as well, for me to update the latest version of BIOS (in case it's needed).
                              On the other hand....
                              Managed to install Linux Ubuntu 21.1 easy - as piece of cake. No problem!
                              Only in Windows there is problem...
                              • Acnologia
                                • Dec 2016
                                • 421
                                • Poland
                                Any other suggestions ? It's strange that this laptop doesn't want to boot from any other device.
                                Only from Linux ...Ubuntu...
                                  • 20966
                                  Does it still have the recovery partition with the original OS ? ,if it does you can install the OS and upgrade to win 10, but make backup images first of the partitions or the whole disk
                                  Notes from bios update https://download.lenovo.com/pccbbs/mobiles/r0duj36w.txt
                                  Be aware that the OS Optimized Defaults option in the Restart menu of ThinkPad
                                  Setup should not be normally changed. Lenovo recommends to use the factory
                                  default setting for it, as follows.
                                  - For Windows 10 64-bit Preload models [Enabled]
                                  - For Windows 7 Preload models [Disabled]
                                  To install the retail edition of Windows 10 64-bit, the OS Optimized Defaults
                                  option should be [Enabled].
                                  • Acnologia
                                    • Dec 2016
                                    • 421
                                    • Poland
                                    No ,it was bought without disk.
                                    I have also "bought from USA"the first recovery image, but again ,it didn't even boot into this image.
                                    I cannot update the BIOS ,due to i don't have the same exact battery in operation mode.
                                    • Acnologia
                                      • Dec 2016
                                      • 421
                                      • Poland
                                      Anyone can share a REV. 3.0 bios dump that works 100% ?
                                        Lenovo ThinkPad E570 Notebook E Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad E570 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E570 boardview and E570 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                        09-06-2024, 08:05 AM
