I've found that RS componets in the UK do most of the caps I want but the 1500uF seems to be non existant in this country. How critical is it for the cap to be exactly this value? Would a 1200uF or a 2200uF be acceptable in its place? The m/b is an epox 8rda+.
I've checked with digikey and they say they will supply low quantites but I'm guessing once post and packing is added it will work out rather expensive so a local solution is preferable.
BTW, you might like to have a look at my site
http://homepage.ntlworld.com/bubo/
It shows infra red thermal images I took of my motherboard. The bad caps thing may explain why some of the mosfets are hotter than others.
