Hi Everyone, I need help on my mac 820-00165-A. Here is the problem:
1. Mac does not turn on when power key pressed. Adaptor shows green then amber and stuck to amber. I tried to reset SMC using the keyboard techniques. Still it doesnt power up.
2. Prior to this, i plugged the MAC at 220v power outlet while it is off and took around 2-3 days plugged in at OFF condition without anybody using it for 3 days. The repairman i talked to said that it is wrong to leave the laptops OFF and plugged in and charged for very long time.
3. As i know a little about electronics, i opened the cover and unplugged the battery cable based on some advise in youtube, but still the problem persists.
4. Then I removed the board and checked on youtube on how to troubleshoot the problem and followed on it to check on some voltages. Here are my findings:
I checked the voltages on the 6 inductors:
L7130 - 8.5V is good. Fuse is good. so there is G3Hot
L7095 - 3.42v is good. That is why the charger has green/amber light
The other 4 inductors have 0 voltages.
Then I focused on the L7560 inductor which has no 3.3V. I traced circuit up to the TPS51980A powerchip and checked the voltages as follows:
Vin (input)(pin23) -8.5V - OK
VReg5 (output) (pin29) - 0V - NOT OK! which is supposed to be 5V
VReg3 (output) (pin22) - 3.28V - OK
VRef2 (output) (pin13) - 1.7V - OK
EN (input) (pin12) - did not check because my probes kinda fat and hard to reach the pin
EN2 (input) (pin21) - 3.3V - OK
VBST2 (input) (pin26) - Ov - Not OK!
SW2 (input) (pin 25) -0V - Not OK!
DRVH2 (output) (pin24) - OV - Not OK!
Pls note that i wasnt able to check other pins because I was afraid to create additional damage, etc.
Based on these readings, I deduced the problem is on the chip TPS51980A BUT im still having considerations on the the capacitor C7505 which is connected to VREG5 of this chip. Either the chip or the capacitor or both are the problems, or any other component. Pls. enlighten me on what to do. Thanks very much for all your help.
