Unlock asus for free
    Re: Unlock asus for free
    2017/08/01
      Originally posted by byulo View Post
      2017/08/01
      try
      2017-08-01 1B0A0ALA
      goodluck
        Originally posted by rioreno View Post
        try
        2017-08-01 1B0A0ALA
        goodluck
        Still invalid, i tried javascript asus password generator but no avail. My unit is Asus ROG G750JX. Thanks anyway.
          here..
          2015-08-03 AAAHHCAA
          2015-08-04 AALABALA
          goodluck
          thank you
            Does anyone have the rescue password for 2017/07/27
              Please help Asus X205ta bios
                2017/08/01
                Here one will work.
                AB0A0ALA
                BB0A0ALA
                LB0A0ALA
                OB0A0ALA
                DB0A0ALA
                1B0A0ALA
                0B0A0ALA
                9B0A0ALA
                4B0A0ALA
                2B0A0ALA
                CB0A0ALA
                HB0A0ALA
                TECHMAN1025
                  Hi, found this thread after some searching, would love a password for 2017/09/02 and 2017/09/03 (or at the date you see this post)
                    try
                    2017-09-02 OLBL4ABA
                    2017-09-03 OAAA9DAA
                    goodluck
                      try
                      2017-09-02 OLBL4ABA
                      2017-09-03 OAAA9DAA
                      goodluck
                      Awsome! OAA9DAA did the trick.
                        Originally posted by techman1025 View Post
                        2017/08/01
                        Here one will work.
                        AB0A0ALA
                        BB0A0ALA
                        LB0A0ALA
                        OB0A0ALA
                        DB0A0ALA
                        1B0A0ALA
                        0B0A0ALA
                        9B0A0ALA
                        4B0A0ALA
                        2B0A0ALA
                        CB0A0ALA
                        HB0A0ALA
                        TECHMAN1025
                        I've try this but no avail.
                          2017/08/01
                          Here one will work.
                          AB0A0ALA
                          BB0A0ALA
                          LB0A0ALA
                          OB0A0ALA
                          DB0A0ALA
                          1B0A0ALA
                          0B0A0ALA
                          9B0A0ALA
                          4B0A0ALA
                          2B0A0ALA
                          CB0A0ALA
                          HB0A0ALA
                          TECHMAN1025
                          I have a TL866LS programmer but don't know how to remove the password in bios dump.
                            have you tried to reset you cmos? will change to default bios date..
                            Last trick , flash your bios..
                              Yes brother.
                                Hi Upload the original bios dump i will remove it for you no problem
                                Techman1025
                                  Hi, please help to get the BIOS bin file for
                                  ASUS X205TA
                                    Hi Asus don't have full updates so original file is needed.. If you use a donor then it will need the ME Region Built..so upload your original and i will help you and give you a working file.
                                    Techman1025
                                      Hi. I need to unlock my ASUS T200TA notebook.
                                      BIOS version : 211
                                      BIOS date : 2015/11/10
                                      BIOS source : https://www.asus.com/us/support/Down...7IsV2XQl4O/40/
                                      First time ALT+R : 2017/08/03
                                      Can use Live-USB to boot from Linux partition.
                                      Boot options do not show up when booting from SSD.
                                      Problems :
                                      * installing Linux required removing secure boot
                                      * changing secure boot require admin password
                                      * password is lost, and BIOS can't be flashed without Windows
                                      * Windows requires secure boot
                                      Tried :
                                      * removing battery for 2 hours, nothing happens
                                      * can set any date in BIOS or Linux
                                      * old rescue password list (https://pastebin.com/L3c3rySj) does not work
                                        Techman1025
                                        Hi,this is dump file from my ASUS T200TA password locked.Could you remove password please?
                                          Hi
                                          hi use a older zip tool ...i can't unzip it ..say corrupted broken link.
                                          Techman1025
