hp 840 g6 6050A3022501-MB-A01
    Re: hp 840 g6 6050A3022501-MB-A01
    Originally posted by Dhaka Lab View Post
    pls remove pass
    HP EliteBook 840 G6
    SERIAL : 5CG9493XZV
    SKU : 8NV12UC#ABA
    FEARTURE BYTE : 3X476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAdUdpdqfPhKhkj4jhk8.E7
    BUILD ID : 19WWCFBT601#SABA#DABA
    Become a Badcaps supporter
    Thanks to all supporters.
      pls rebuild this bin for me, it is corrupt
        ???????? Where's your *.bin file ?
          help elitebook 840 g6
          help to remove pass from this dump pls
            Re: help elitebook 840 g6
            the file
              the file
              Here's your Unlocked file, hope it works fine.
              Next time you can do it using RCUnlocker tool.
              all donations are welcome,
                hi can you remove password, I tried rc unlocker but show error using de 32mb flash
                hp elitebook 840 g6
                sn:5CG9270F7R
                BUILD: 19WWCFAT602
                FEATURE BYTE: 3X476J6S657B7H7M7Q7W7m7saBaEapagauawbUbhcAdQdUdpdafAgShkink8
                thanks
                  hp elitebook 840 g6
                  sn:5CG9270F7R
                  BUILD: 19WWCFAT602
                  thanks
                  use RCUNlocker on the 16MB bios..
                    need to do something on the 32mb flash?
                      Just use RCUnlocker with your 16MB and see what will happen.
                      Be careful, your 32MB file not good, you should read it again before doing anything.
                          Read the posts above, use RCUnlocker on the 16MB backup
                          https://www.badcaps.net/forum/showthread.php?t=103526
                            Hola alguien me podria desbloquear los .bin por favor
                              Read post #292
                                HI EVER ONE HERE IS hp 840 g6 bios can me clean this bios problem is nodispaly
                                  hello can someone remove computrace + bios administrator password thanks
                                    Re: HP 840 G6 Bios Password
                                    Hello Peste.
                                    How did you remove password?
                                      i have sucessfully removed my password in hp 840 g6 by getting the bios from the website and flash 16mb and 32mb.. upload ur original bios here and I will unlock it for you
                                        help to unlock this file master.
                                        thanks in advance
                                          thanks in advance
                                          See post #294
