GA-8S655FX with very hot FET
    Re: GA-8S655FX with very hot FET
    Could you tell if USB ports, Video, Sound, LAN were working?
    That's the point of it.
    It's a EASY QUICK way to tell if you have a hardware or windows problem.
    It's open source.
    If you want an advance testing package you can make one.
    Mann-Made Global Warming.
    - Dr Seuss
      I found yesterday that a friend have the same board. He is having problems but finally found it was couse a bad memory module.
      I told him to check the fet that gets so hot and also measure the voltage in the pins.
      He told me the FET doesnt get hot and the voltages are the same as the ones I got.
      D - 3.32v
      S - 1.90v
      G - 6.30v
      For my understand this indicates that the FET is working fine and there is someting in the FET output that is consuming too much. It could be the southbridge. I need to discard its not something out the southbridge.
      any ideas ?
      can be the FET ?
        hot FET can also mean bad regulator controller IC pumping bad signal to FET. I had dell D600 fry a totem-pole FET IC (blow a crater) every time I swap it, fix was replace both regulator controller IC and this FET IC. Now I have a working D600.
        Cheers, Wizard
          If the MOSFET is regulating the controller should be OK. Two prospects
          1. Southbridge load too heavy or anything else loading up the circuit.
          2. Possible oscillation in MOSFET regulator circuit. Least likely.
          Gigabyte EP45-DS3L Ultra Reliable (Power saver)
          Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
          160Gb WD SATAII Server grade
          Nvidia 8500GT 256Mb
          160Gb WD eSATAII Server grade for backup.
          Samsung 18x DVD writer
          Pioneer 16x DVD writer + 6x Dual layer
          33 way card reader
          Windows XP Pro SP3
          Thermaltake Matrix case with 430W Silent Power
          17" Benq FP737s LCD monitor
          HP Officejet Pro K5300 with refillable tanks
            This is what I think too.
            You need to find a diagram/schematic of chipset and explore inputs/outputs.
            I don't know where you'd find one for SIS.
            - Dr Seuss
              I found the datasheet for the SiS 960 but nothing on the SiS 964 or the complete chipset SiS 655 Fx
