I'm looking for the hp pavilion 15-cb schematic. urgent .
hp pavilon 15-cb schema . please .
Re: hp pavilon 15-cb schema . please .
Originally posted by selim guney View PostI gave the laptop for repair. mosfets have been changed. I need original mosfets and driver mosfets. driver mosfets coded . for example (7=j 4g 50g ) example . he needs a sky.
Beginner's guidelines
https://www.badcaps.net/forum/showthread.php?t=88758
1.1.3 Motherboard model number
Motherboard model number is the most useful if you are troubleshooting a motherboard problem. It helps finding pictures, schematics, boardviews, known issues…
There is always a number written on the board itself. In some cases there's also a sticker that tells a variant.
There are several different board manufacturers, common ones are:- Quanta: found in HP, Dell, Acer, Toshiba, a few Lenovo… Model number on the board is "DA0xxxxMByyy" (first 0 is optional), "xxxxx" is the actual model and "yyy" contains the revision. For example DAY11AMB6E0 for Quanta Y11A rev E. Warning: 0 and O are hard to distinguish when reading from the board, for example DA0OP6MB6D0 for Quanta OP6.
- Compal: found in HP, Dell, Acer, Toshiba, Lenovo… Model number is "LA-xxxxP" (P is optional), the older, the lower the number is. Like LA-4082P from 2007 or LA-E541P from 2017.
- LCFC: found in Lenovo, it's actually Compal. Model number is "NM-xxxx"
- Wistron: found in Acer (Wistron was part of Acer a long time ago), some Dell, HP, Lenovo… Model number is a "xxxxx-x" (x being a digit), often associated with a name. For example "Richie MB 11241-1".
- Inventec: Toshiba, some Acer, HP… Model number is often "xxyyzz" with "x" being a letter, "y" a digit and "z" an optional letter. There's also a "6050xxxxxxxx-MB-xx" number that can be easier to spot. For example "SA10E" and "6050A2052401-MB-A04" for Inventec San Antonio 10E.
- Foxconn: Sony, some HP. HP have a weird model number like "CHICAGO_HR_HPC MV_MB_V1" or "PM_I_HPC_S MV_MB_V3". Sony come with an "MBX-xxxx" number that's easy to identify, and another number, like "MBX-202" and "M790".
- Pegatron: a few Acer and Toshiba. Acer in general have a "xxyyzz" with "x" being a letter, "y" a digit and "z" an optional letter. Toshiba have a weird model number like "PLF/PLR/CSF/CSR UMA"
The following manufacturers make their own boards (except maybe a few models here and there):- Apple: board model number is "820-xxxxx", like "820-3462". It's written black on black so it's hard to spot.
- Asus: board model number follows the same format as the laptop model number, it can be the same or similar, and sometimes different.
- MSI: model number is "MS-xxyxz", with x being digits, y a digit or a letter and z a optional digit for the revision. Some boards have 2 different model numbers like "MS-16J5" and "MS-1795" (with a 1 appended for the revision).
- Samsung: model number is name associated with a "BA41-xxxxxx" number, like "Bremen-D" and "BA41-01197A".
- Clevo: they manufacture laptops for a lot of "small local" brands. There are often 2 model numbers on the board, like "6-71-W25S0-D02" and "W251ESMB-D0".
- Toshiba: a few business grade machines only. Something like "FLESY3" or "FHNSY1"
HannStar don't design boards, they manufacture the PCB. "J MV-4" and "94-V0" are not board model numbers, they are generic markings about PCB characteristics.
If unsure, send high-resolution pictures of the board. They are always welcome in any case.
Originally posted by selim guney View Posthi . . hp pavilon 15-cb007 nt .
motherboard . dag75ambado rev d
Originally posted by selim guney View Postthe actual numbers of the components do not exist.Attached Files
