hey folks,
working hard on this one and I'm pretty stuck. PP5V_S5 was originally shorted dead to ground because of a bad cap (C6213). In the process of finding that, I injecting 5V into the rail to see what would heat up...which didn't help much.
I removed the audio amps, removed and replaced U7300, removed and replaced U5930 (accident).
My problem appears to be no PM_SLP_S4 (its stuck low, though not shorting).
PP1V05_S5 - 1.04V
PP3V3_S5 - 3.3V
PPBUS_G3H - 12.57V
PP3V42_G3H - 3.34V
I injected 5V into PP5V_S5 and it draws very little, so I think the short is no longer the issue now that the cap was removed. But maybe it shorts when EN lines are activated? I notice that it is ~10ohms to GND when magsafe is plugged in. My scope shows nothing pulsing on the lines either.
Should I remove U7300 (TPS51116) again ? Or remove U6201 (audio decoder)? these are the best candidates for 5V_S5 issues...though I'm not sure if I should be looking for something else..
Thanks!!
PP1V05_S5 - 1.04V
PP3V3_S5 - 3.3V
PPBUS_G3H - 12.57V
PP3V42_G3H - 3.34V
Thanks!!
