PLEASE Hp 14-cf1061st CLEAN ME BIOS
    Good evening, please does anyone have a bios dump Hp 14-cf1061st HEDWIG2 - 6050A3155301 - MB - A01 working and region clean?
    Thank you very much for the help.
    Re: PLEASE Hp 14-cf1061st CLEAN ME BIOS
    bios extracted from the HP site update, the laptop has four versions of the bios, yours is 0852C
    DMI + KYIWIN 310000-31103F
      Tried several times without success with )))
        Motherboard has start but no display. Any ideas?
          my bios dump is corrupted.
          I can't do anything with it.
            Look around the board for another bios chip, i think it has two.One is for surestart recovery.Post it if there is one (backup) and some pictures with both chip locations.
              is only 25Q128 bios chip
                Ok, try this one. There are two 0852C bios in the extracted upate,not sure why yet but both have differences.
                  works 100%!!! thanks!!!!!
                    the problem with laptop is that it goes to sleep mode and won't turn on during some time. When i trying to turn it on, it turns on after several minutes with 0,30 GHZ frequency and normalized after 40 min. I was trying to gat bios ME region but i got error -the me/txe region is corrupted or missing. Do you know what the problem is?
                      The bios you posted has BID0852C so we can only assume that the bios was the original one. I`ve now found your bios on another site (paid) for the exact model number 14-cf1061st and the BID is different, its 08498 .Is the laptop serial number 5CG9404YVW ? ,If it is then the DMI info can be added to the 08498 posted by @peste, thats if the DMI info is stored at the same address,and if it isn`t use HP bios config utility/wndmifit to add it.
                        Tried several times without success with ))) 25Q128 bios chip
                        this is my serial number 5CG9404YVW!
                          Works For Me. Thanks A lot
                            Thank's working
