Hi I got Sony kdl-46w905a and it won't turn on and no red blinking code and all I hear when I plug it in is a clicking noise and a pause for a second then another clicking noise as if the power supply has a relay and is relay is turning off the power supply bcuz of a problem, bcuz of this I have no way to check voltages anywhere as there's no standby light but I think I get a white light for a second then goes off, I've checked for bad capacitors or shorted mosfets but haven't found a problem, and I was thinking if there's a way To bypass the protection so it stays on so I can check voltages ? Or maybe someone can help me on what to try ?
Sony kdl-46w905a won’t turn on and relay clicking noise
Re: Sony kdl-46w905a won't turn on and relay clicking noise
Originally posted by nomoresonys View PostUnplug from power, unhook cable from powerboard to mainboard, plug power back into powerboard, do backlights come on and is the clicking the same?
Ok, with everything hooked up do test #3 below, demonstration in #2 if needed, try to do just as instructed, this test is done on the cold side, as always BE VERY CAREFUL when working with the HOT/DEADLY side of powerboard.Last edited by nomoresonys; 10-20-2019, 12:05 PM.
Originally posted by nomoresonys View PostOk, with everything hooked up do test #3 below, demonstration in #2 if needed, try to do just as instructed, this test is done on the cold side, as always BE VERY CAREFUL when working with the HOT/DEADLY side of powerboard.
Could try jump starting power board and see if you get the missing voltages, with cable from powerboard to mainboard UNHOOKED, make sure it is, then connect low wattage resistor from POWER..ON to STBY 3.3 and another resistor from STBY 3.3 to BL_ON, power up powerboard, see if you get the missing voltages and if the backlights come on and stay on.
Originally posted by nomoresonys View PostCould try jump starting power board and see if you get the missing voltages, with cable from powerboard to mainboard UNHOOKED, make sure it is, then connect low wattage resistor from POWER..ON to STBY 3.3 and another resistor from STBY 3.3 to BL_ON, power up powerboard, see if you get the missing voltages and if the backlights come on and stay on.
That test in post #8, if passes usually verifies powerboard and backlights, leaving either a mainboard, tcon, panel issue or connection.Last edited by nomoresonys; 10-21-2019, 08:49 AM.
Demo there, HEED THE WARNING OF DEADLY VOLTAGES ON HOT SIDE, he used an alligator clip to short pins together, it's recommended to use a resistor so you don't mess up any components in case you accidentally short the wrong pins: https://www.youtube.com/watch?v=mUvclBfaMXg
Originally posted by nomoresonys View PostDemo there, HEED THE WARNING OF DEADLY VOLTAGES ON HOT SIDE, he used an alligator clip to short pins together, it's recommended to use a resistor so you don't mess up any components in case you accidentally short the wrong pins: https://www.youtube.com/watch?v=mUvclBfaMXg
