Hi guys
I have this MS-7592 motherboard
It powers on for about 10 seconds then powers off again, it then powers back on and repeats the cycle
It came with a Core 2 quad -I tried another Core 2 quad, both stop with POST code E1 then it shuts down after a few seconds and restarts.
If I remove the RAM it beeps as you would expect - then shuts down as described above and restarts.
I also tried a Pentium D that is compatible with the motherboard. Same thing apart from it sits on code 98 for a few seconds, then goes to F1 and shuts down....
There are some DIP switches marked OC-SW and it's fairly obvious what that is for - but strangely there is no mention of the switches anywhere in the manual from msi site. Does anyone know the correct default setting?
PS I did have a CPU cooler on.
