Re: VGA scan conversion alternatives
First, that document in the first post comes up empty for me, unless I edit it in a dos box and then it contains a few words but mostly jargon.
From what I'm seeing online about the VFX1, it accepts normal VGA. But you seem to believe it has to be converted to something other than VGA. If it still uses RGB + Sync whether it's H+V or Composite Sync, it could only be converted to PAL or NTSC if anything other than VGA, right? Which would be 31kHz scan rate versus 15kHz scan rate, respectively.
But again, from what I'm reading, the VFX1 uses only VGA hookups. This leads me to believe that the box you're trying to build is nothing more than a couple of LCD drivers combined with some sort of re-distribution for the RGB + H/V Sync. I don't think you can run two monitors off the same hookup so this box probably contains some form of repeaters.
The Televiewer page I saw didn't mention any RGB output, only Composite and S-Video. I saw a mention of VGA throughput, but no PAL/NTSC RGB output.
