i have a seasonic psu model seasonic ss-520gb, with drop voltage and bad voltage regulation
Measure with digital multimeter,
Load using my trusty dummy motherboard and 3 hard drive:
12v rail give 11.35-11.55v with (very) rapid changing.
And same thing with the other rail.
But if no load, shorting green and black cable, it can provide up to 11.85v.
What about the dummy? maybe this one cause error.
Nope, i've already tested this dummy (motherboard+hdd) with other psu, and still give strong 12v voltage
All caps is japanese. physically check, all non bulging caps.
I've checked the component in primary and secondary, change tl431 ic, all 3 optocoupler, primary and apfc mosfet and supervisor ic (HY-51n), even i've tried to replace main transformer from other same psu, but still no luck.
can bad cm6800g cause this issue?
or bad capacitor in secondary?
or maybe any other advice..
Thanks alot for the enlightenment..
