Hi, I have a problem with an ASUS X451CA MB, I have no signal + 3VS_LCD. I have the doubt if the PCH administers this signal. The equipment turns on but does not give a video signal, however the oscilloscope records output data in PCH. Any ideas? Thank you.
No signal + 3VS_LCD on ASUS X451CA.
Re: No signal + 3VS_LCD on ASUS X451CA.
Originally posted by karlox View PostHi, I have a problem with an ASUS X451CA MB, I have no signal + 3VS_LCD. I have the doubt if the PCH administers this signal. The equipment turns on but does not give a video signal, however the oscilloscope records output data in PCH. Any ideas? Thank you.
I have the 2.0 & 2.1 version
but it seems to be differrent from yours ( based on the image of your post )
Come back, I still have no video signal, the mosfet q4601 seems to think it was the problem, look for a replacement and install it but when you put it the signal is + 3vs_lcd. Checking the diagram, a line goes to the PCH, I think I suppose to have a fault there or it is dead. Any ideas?
As far as i can see to open +3vs_lcd_on mosfet q4602 you have to have +3vslcd_en signal which is generated through q4601 mosfet. And to generate that signal you have to have l_vdden_pch which is generated through pch. So its either pch dead or problem with the bios...
Originally posted by myth77 View PostAs far as i can see to open +3vs_lcd_on mosfet q4602 you have to have +3vslcd_en signal which is generated through q4601 mosfet. And to generate that signal you have to have l_vdden_pch which is generated through pch. So its either pch dead or problem with the bios...
