I have a problem with a TV of mine. I would try to explaine as much as possible.
When I put in the power cord. You hear relays clicking that's normal. The TV is starting up right away but not with a picture.
You can use the power button on the TV itself to turn it off again an it reacts normal and shuts off.
You also can turn it on again with this button.
Also with no picture coming.
What I noticed is that the logic board never gives a flashing green led. It also doesn't matter if I disconnect the y-sus and z-sus boards.
The next thing i notice is that the digital audio port on the mainboard lights up when you start up the TV and then slowly goes out after a second or 2. Doesn't come on again if you let the tv on.
I have measured the voltages and they look fine in my opinion.
Vs are good and in range Va also and steady.
The only thing I don't understand is what is the pin 17v-det does.
I m measuring about 3v at that pin.
One more thing is that I slightly hear a ticking noise coming from one of the transformers at the power supply board don't know if that's good or bad. It's not as loud as a relay but just a little tick. And it is constant there every second. But what I mentioned I measure good voltages.
I hope someone can help me with this problem
Especially whit the logic board and the mainboard. How I can test those 2. Or measure some things to be sure where the problem is coming from.
Thanks for your messages.
Ps if I have to upload pictures it can take a little time because I m very busy at the moment.
