Just replaced the heating element on my iron and noticed it’s a little shorter than original and doesn’t fill entire length of the tips. Will it affect the temperature reaching the tips or shouldn’t matter?
Is this soldering iron heating element too short?
Re: Is this soldering iron heating element too short?
Are you sure the new heater is shorter?
I would check the tip's depth (inside) and see if there is now a big air gap. Kind of depends on where the sleeve bottoms out now.
For best heat transfer and temperature accuracy, you don't want air gaps.
P.S. what tip is that, it looks niiiice
Yeah there’s a gap. The depth inside the tip extends out the same distance as the red mark I made.
https://www.ebay.com/itm/24V-50W-4-p...b/141450226877
Originally posted by stj View Postit's no good - maybe a manufacturing defect.
you need it to fill the tip or the feedback wont work.
Will it cause any issues using it like that until I get another?
