HP Elitebook 2540p Blank Screen
    Mainboard ID: KAT10 LA-5251P Rev.1.0
    Schematic: https://www.badcaps.net/forum/showthread.php?t=50452
    Tried bios from https://www.badcaps.net/forum/showthread.php?t=50452 on post #7
    Measuring DRAMRST# signal on pin30 of DDR slot it's only 0.26volt
    On Q52, pin1 0.26v, pin2 3v, pin6 0.26v
    Caps lock & num lock led blink slowly five times then off (not blinking)
    changing ram module known good and without ram module will give same blinking code
    all voltages present on this board
    is the voltage on pin30 of ram slot correct?
    please advice...
