Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Major Manufacturers Boards
Thread Tools Display Modes
Old 01-30-2018, 03:40 PM   #1
inwerp
City & State: Munchen
My Country: Germany
I'm a: Knowledge Seeker
Default Lenovo 500-15isk - Charging/Power problem
Hello everyone.
I am new here, and i am new in the industry(i started to work in a local repair shop a few weeks ago).
I have a laptop Lenovo 500-15isk with the following symptoms:
starts with the battery, do not charge|does not see DC adapter.
without battery turns on for a second, then shuts down. Amp consumption hits 0.5A then goes back to fluctuation 0.1..0.2 with a tiny noise near the charging circuit.
Could not find schematics diagram and i also do not have enough experience to find all control voltages without it.
I would appreciate any clues and ideas.
inwerp is offline   Reply With Quote
Old 02-01-2018, 12:41 PM   #2
inwerp
My Country: Germany
Default Re: Lenovo 500-15isk - Charging/Power problem
So I fixed this board today. after checking chip voltages i found that VCC drops from 19v to 3.1v on one tiny resistor which looked more like a fuse. i googled a little bit and found the same exact problem with the same exact symptoms on some Russian forum. I decided to short this resistor and it really worked. It was a 10om resistor, and i replaced it with a tiny copper wire.
even though i could not find this board schematics anywhere, chip datasheet really helped me to troubleshoot this issue.
Old 02-05-2018, 07:32 PM   #3
crash-cyberdrive
crash-cyberdrive's Avatar
City & State: Puerto Rico
My Country: US
Line Voltage: 120VAC 60Hz
Useful information Thank You for sharing.
__________________
A Picture of subject is always Welcome
Things saved from the e-landfill:
Vizio VA26LHDTV10T 26" - Bad EEPROM Cap
Asus PTGD1-LA Full Recap - Cha1 DDR socket damage
MSI PM8M3-V Unstable CPU Recap CPU VRM circuit
ViewSonic VA712B - still working on it
Kindle Fire USB Connector
MSI G31M-F Full Recap - Record Breaker done in 3Hrs.
MSI P67A-G43 BIOS chip Reprogram - Tested and Happy
The list will go on thanks to the people of this forum and many hours of reading.
crash-cyberdrive is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
