Jetway A210GDMS-PRO is an Athlon64/Socket 939 PATA-IDE/SATA MoBo. It died because of six oozing caps with a "K" vent, all marked FZ51 1500micF 6.3V
Jetway A210GDMS-PRO
Re: Jetway A210GDMS-PRO
Those are Sacon FZ series ... they're well known here, they die a lot. Replace all of them with something suitable.
Replace with 1500 uF 6.3v 0.022 ohm or lower impedance , 1800 mA ripple or better, 10mm wide (or wider if you have the room).
example:
http://search.digikey.com/scripts/Dk...name=P12343-ND
http://search.digikey.com/scripts/Dk...me=565-1633-ND
http://search.digikey.com/scripts/Dk...HM0J152MPD3-ND
ps. be careful, some of those caps near the atx connector are 16v , probably 470uF - they have the same ripple and impedance value as the 1500uF 6.3v.I'd replace the four around the connector as well.Last edited by mariushm; 09-10-2011, 01:10 PM.
