Latitude 1F5A
    Re: Latitude 1F5A
    Hello.
    Can anyone help me please!!!
    I need a password for my dell precision
    service tag: 4S5VN4J-1F5A
      Re: Latitude 1F5A
      Hi all, need the password for dell E4310 with this tag:
      # 2TK70P1-1F5A
      Thank you in advance, write in English through google translator, sorry if something is not right.
      Greetings from Barcelona.
        Re: Latitude 1F5A
        i have a dell e4310 set with the administrative password.
        System Number DX601P1-1F5A.
        Please help me with the password.
        Thank you.
          Re: Latitude 1F5A
          Hi, I need a bios dump from dell latitude e4310.
            Re: Latitude 1F5A
            Hi please help me,
            for my Notebook E6400 and an Bios Adminpassword
            CX8R44J-1F5A
            BX8R44J-1F5A
            thx a lot
              Re: Latitude 1F5A
              I have a dell latitude e 6400 with service tag #82BJ64J-1F5A . Please help me with a bios password
                Re: Latitude 1F5A
                Hi
                Try to find a clean dump and use a programmer
                To flash bios eeprom.use old version dump so the
                Tag extension(1F5) change and you can use masterpassword generator
                  Re: Latitude 1F5A
                  please help.......dell e5500
                  #GR3H94J-1F5A
                  Originally posted by rithien View Post
                  try this:
                  Latitude E6410
                  Master Password: 6sDD9MGlsnIlOzGX
                  For better font use this :
                  Password is case sensitive !
                  Passwords are for QWERTY keyboard only (standard US)
                  Enter calculated password, Then holding CTRL push ENTER key twice.
                  If you have admin password only pres ENTER
                    Re: Latitude 1F5A
                    try this:
                    Latitude e6410
                    master password: 6sdd9mglsnilozgx
                    for better font use this :
                    password is case sensitive !
                    Passwords are for qwerty keyboard only (standard us)
                    enter calculated password, then holding ctrl push enter key twice.
                    If you have admin password only pres enter
                    can you help me ....
                    S.teg. #ffdh6bs-1f5a
                    how remove password....
                    Thanks....
                      Re: Latitude 1F5A
                      Hi, i have a problem with bios password for me Dell Latitude E4200. This Laptop have a service tag FC7PV4J-1F5A. I have need this password bios for UNLOCK... Thank you very much
                        Re: Latitude 1F5A
                        Hi for all
                        as i explain above, you must downgrade your bios version.
                        For that, you must use programmer and find and old version
                        of bios. You can download old version of bios from dell website
                        and programm your eeprom with that. And you must use dell service
                        password to retrieve this.
                          Re: Latitude 1F5A
                          Originally posted by razadom View Post
                          Hi for all
                          ok, i have install BIOS REV.22, this problem is not resolved, this tag service and 1f5a not change...
                          thank you
                            Re: Latitude 1F5A
                            thank you
                            If you have save lock bios post here.
                              Re: Latitude 1F5A
                              hai
                                Re: Latitude 1F5A
                                Originally posted by techetronic View Post
                                hai
                                Yes....
                                  Re: Latitude 1F5A
                                  ok this image is to switch on and later push f12
                                    Re: Latitude 1F5A
                                    [QUOTE=Severus87;832194]ok, i have install BIOS REV.22, this problem is not resolved, this tag service and 1f5a not change...
                                    Try downgrading to A13 A13 bios https://downloads.dell.com/bios/E4200A13.EXE
                                      Re: Latitude 1F5A
                                      No i say you have bios programmer read bios chip save and post here.i will send change service tag number.
                                        Re: Latitude 1F5A
                                        OK! Installing ok. This new tag is FC7PV4J-2A7B.
                                        I have used password in bios-psw
                                        this not function! I have lose hope....
                                        Help me... thanks
                                          Re: Latitude 1F5A
                                          Use capital letters for the serial and press ctrl+enter after entering the password. You give up too easily .
