Hi All, I have read a lot here but First time posting. I could use some help....To make a long story short, I have/had two LG 50PS60 TV'S and one died yesterday so to diagnose the problem I was swapping out boards and found out the hard way that ZSUS boards must be fully mounted with all screws to be grounded properly. I swapped the ZSUS board from the good TV and put it into the broken TV and all worked well so I removed it and put it back into the original TV that had no issues but stupidly I just put a couple screws in to start it up and test to make sure all cables are good, TV came on for 10 seconds and "snap" screen went dark with a redish background. The fuse did blow on the board and I have replaced it but now the TV will turn on for about 3 seconds and shut off. I am assuming I popped a resister or diode ??? Have I totally fried the board or is there something I can replace to repair the board. Thanks in advance.
I think I fried a good ZSUS board on an LG plasma
Re: I think I fried a good ZSUS board on an LG plasma
They are very cheap on ebay. Make sure you get the correct one, as there are about 5 versions for this tv. I think it would be cheaper to just replace the board(s) than to buy all the things you blew up.allways put all screws back in everything!!!
Yes unfortunately you have damaged the board without installing all of the screws. But the question is whether it is worth repairing or not. If you do not have the experience and knowledge to repair a Z-sustain board it is probably not worth doing especially if you can get a new board for relatively little as tvtimmy says... Chalk it down to a lesson learned I guess...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tvtimmy View Postalways put all screws back in everything!!!
Originally posted by tom66 View PostYes unfortunately you have damaged the board without installing all of the screws. But the question is whether it is worth repairing or not. If you do not have the experience and knowledge to repair a Z-sustain board it is probably not worth doing especially if you can get a new board for relatively little as tvtimmy says... Chalk it down to a lesson learned I guess...
You would need to check all of the IGBTs (transistors) on the heatsinks to see if any are shorted.
If they are shorted they will need replacing. You can remove them from the circuit to confirm.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tom66 View PostYou would need to check all of the IGBTs (transistors) on the heatsinks to see if any are shorted.
And are you talking about all the 45f122, rf2001 & 20nf20 transistors on the heat sinks ?
Yes I'm talking about 45F122 and 20NF20. RF2001 does not need testing - it is a fast diode and unlikely to fail.
You should check all three combinations and they should all appear open circuit. A low value in any direction indicates a fault (confirm by removing the device and checking out of circuit.)
It is common for only a few parts to be bad, but when tested in circuit many can look bad.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tom66 View PostYes I'm talking about 45F122 and 20NF20. RF2001 does not need testing - it is a fast diode and unlikely to fail.
You can only omit screws if you're willing to trace through the board and figure out which ones are really necessary. There are some boards also that use the heatsinks to pass the ground plane through. I have learned that lesson too when trying to run a board without the heatsink. Thankfully I had a bulb in place so it didn't blow up anything but it certainly didn't work.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
