I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked for 1 day and then quit working.
I use a universal remote and can control the receiver. That means the receiver has no problem in receiving IR signal.
But, I also found that whenever I press the buttons on the Pioneer remote control, the red led of the IR receiver of another equipment will light up for a second. (Other remote control for other equipment will do the same). Will this mean the Pioneer remote control is emitting IR signal? If yes, why the Pioneer receiver does not response to it?
Why the remote control just work right after cleaning only?
Could someone please give me some suggestions on how to fix this problem?
