Asus x555uj notebook 19v no input. With which program I can see the value of PR8929 resistance in the boardview file. charge control BQ24780 AC_DET input is missing. I'm looking for a program.
Re: Asus x555uj notebook 19v no input.
Originally posted by mon2 View PostYou can try a different boardview file reader which may offer more details.
Can you post the boardview file here for a review?
https://www.badcaps.net/forum/showthread.php?t=91136Last edited by SMDFlea; 10-04-2023, 05:12 AM.
the file here. I am using boardview version 2.1.0. but I can't see the resistance values. Which program do you need?
https://www.badcaps.net/forum/showthread.php?t=91136Last edited by SMDFlea; 10-04-2023, 05:13 AM.I'm not happy to be so strong. because it's not humanly
Hi. Please see attached. Post back if you have trouble in reading these files with your viewer.
.Last edited by SMDFlea; 10-04-2023, 05:13 AM.
Thanks a lot for getting back to me! So I've seen that this is a 1000pf 50v MLCC 10% unfortunately stupid as i am i already ordered a 470pf 50v 10% because i had the wrong boardview in the beginning, that was the same setup also for a 19v power rail. Do you by chance know if you could just use the 470pf one or do i need to get 1000pf?
Thanks again in advance for your help!
Can you post which cap you are referencing ? The voltage of the caps is the same which is good.
The capacitance is not that far off and should most likely work ok but need to review how it is used in the design. It could be a filter cap or could be used as a delay, etc.
I'm pretty lost regarding this. I replaced the cap and it didn't work, now I thought it might be a short to ground, but I tried using current injection to find it and nothing gets hot, instead the thing turns on and works perfectly fine. the only other thing I could think of is that the mosfet right below the cap might be defective but I don't know how I would find out. I think I'll just try to find a replacement for it and if that doesn't work I might just as well try bridging that part and seeing if it works, because if the mainboard breaks I'd need to replace it anyways.
Do you have any other ideas?
