Re: 19 polaroid tla-01911c
Thanks for the data sheet info. That helped to check out the inverters. They all looked good with my DVM on diode. all juctions were > 600 ohms.
This tv has two driver packs that drive two pair of ccfls in series. They are connected from one side of the secondary in series to the other side of the secondary. the point where the pair are connected in the middle is sent back to the board through some 2k resistors (4k total). I assume this is a current measuring provision.
It is difficult to measure voltages since all this is under the board. I may try to solder some wires and run them out so I can measure them easier with the power on.
Do you know what would be an appropriate dummy load for the ccfls?
Thanks again for you help.
Dennis
Dennis
