Re: Sanyo DP42849 - No Power At All
going to take a bit of work if OP has no experience
dmm black probe in COM socket.red probe V MA socket
what voltage with power lead plugged in do you see on the input power cable?,measure directly off the 2 mains pins.you should see 120 ish volts there.
check fuse on circuit board,(white one),meter set to ohms,should read very low resistance or meter will beep,this indicates good fuse
