Old 03-28-2018, 11:20 AM   #1
soralz
City & State: Taipei
My Country: Taiwan
Default Viewsonic VA1912wb-4 after replace cap still not working
Hi guys, I am having a problem with my Viewsonic VA1912wb monitor. It can turn on and got image (can see it thru using flashlight), but the inverter was out. At first I thought was capacitor problem. And I found out 4 of the capacitors are leaked and bulged. Then I replaced all at the outputs area but after trying again the same symptom still occurs. The only capacitors I didn't replace is the big one and the 2 small ones in the middle, rated at 22uF 50v and 47uF 50v respectively. If I change those 2 will it assure the inverter will work again? If this fails I don't plan to invest anymore on it. Or is it probably the primary capacitor fails?
soralz is offline   Reply With Quote
Old 03-28-2018, 03:01 PM   #2
neisg1
City & State: Naicam, Saskatchewan
My Country: Canada
Default Re: Viewsonic VA1912wb-4 after replace cap still not working
Some boards have a small pico fuse near the inverter. Could be the other 2 small caps also check the inverter transformer 2874005300m. With the power disconnected use a multi-meter the coil on the primary side should read close to zero maybe 1 or 2 ohms. The two secondary side coils should each read between 1k and 2k ohms and should both read the same. That transformer is available on eBay for under $10.
neisg1 is offline   Reply With Quote
Old 03-29-2018, 02:43 AM   #3
soralz
My Country: Taiwan
Alright I checked the transformer it got 8 pins, 4 connections it reads 750 ohms for both the top and bottom ones. The middle two shows 0.2 ohms.
Old 03-29-2018, 08:50 AM   #4
neisg1
My Country: Canada
My transformer is a similar type but different part number. My bad one read about 0.1-0.2 ohms on the primary side. One winding of the secondary read 1020 ohms the other was 848 ohms. When I opened it up the 848 ohm side had burn marks. Yours must be a bit different specs. but as both secondary windings show exactly the same at 750 ohm i wold assume it's is ok. Not likely that they would both fail with the same 750 reading. I ordered a new one but don't have it yet.
Old 05-15-2018, 07:16 PM   #5
starling22
City & State: Burnie Tasmania
My Country: Australia
Just of curiosity, what happened hear? success
I am just starting to look at my va1912wb which has symptombs of capacitor problems, takes long time to turn on and clicking sound with flashing green light.
starling22 is offline   Reply With Quote
