Good afternoon. Tell me, I'm recording the flash memory 25b256dyig of this laptop using CH341A. There is no adapter, soldered directly to the flash drive, reads normally, but writes only zeros, after writing one FFFFFFFFF and 00000000
Available software include: NeoProgrammer, Colibri, AsProgrammer, Flashrom…
---------------------------------------------------------------------------------------------------------------------------------------------------------- All donations to Badcaps are welcome. Become a Badcaps supporter >>>>>click on this link to donate <<<<< Thanks to all supporters.
Good day everyone, please i need help on this system, it power on fine but it does not display at all. EDC40 LA-G871P
Your Backup file not good, try to read it again correctly and also write your device Service Tag.
all donations are welcome,
>>>>>click on this link to donate via PayPal.<<<<<
Every donation made will go towards server fees and maintenance costs. ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
It work perfectly sir. Thank you thank you thank you.
You're Welcome.
does this file works only to the bios with that serial number or to any bios?
It should works with any device has the same model number and board number, maybe you will face some issues because it's not your Original Bios.
The best way is to upload your Original Backup, write your Service Tag and someone will try to help you.
At first boot press F2, write the service tag, save & restart. After that at the second boot press Alt+F to exit manufacturing mode. And the fan will slow down.
First boot will be much longer than usual just wait, if you have programmed and soldered the chip as it should everything will be OK, if not do it again.
---------------------------------------------------------------------------------------------------------------------------------------------------------- All donations to Badcaps are welcome. Become a Badcaps supporter >>>>>click on this link to donate <<<<< Thanks to all supporters. ----------------------------------------------------------------------------------------------------------------------------------------------------------
