The 2 Green Sanyo caps are swollen and I wish to replace them (the board does not work anymore and throws an error that I believe is related to the caps). The problem is that I cannot find someone who sells the capacitor in the USA. Ebay pulls up several companies out of Hong Kong that are selling capacitors that look like the ones on the board, but I am not sure and concerned about fakes.
It has qty: 2
Sanyo WF Series Capacitors (I believe these are ME-WF)
6.3V
1500uF
10x12.5mm
0.018 ohm ESR (100kHz, 20C) (From ME-WF Spec sheet)
1760mA ripple current (100kHz, 105C) (From ME-WF Spec sheet)
I cant get good pictures, but here is the writing on both sides...
Side 1:
Sanyo
1500uF
6.3V
Side 2:
105C
S.E.6D
WF
I see that Bad Caps has 2 capacitors that are similar size, voltage, and capacitance but they have a lower ESR and higher ripple current.
Questions:
What capacitor do people recommend (I could probably lay the capacitor over if I cannot find one in the same size. If the capacitor is taller than 13mm, it will hit the computer case)?
With ESR and ripple current, what is better, higher or lower values?
It has qty: 2
6.3V
1500uF
10x12.5mm
Side 1:
Sanyo
1500uF
6.3V
Side 2:
105C
S.E.6D
WF
Questions:
