LCD LED EDID EEPRom Dumps
    • 21853
    Re: LCD LED EDID EEPROM Dumps
    Originally posted by rediii
    looking for edid .bin for dell latitude e6440 - boe - hb140wx1-400. got this dump is it correct? i found it via edid list (github), but i'm bit insecure
    Did you mean unsure ? . It looks ok to me , google this: hb140wx1-400 M2JM1
    • rediii
      h???, spurrrn
      • Mar 2018
      • 501
      • somewhere in europe
      #62
      unsure/insecure, whatever . yeah unsure, if the .bin is the correct one. thanks!
        • 21853
        Lenovo G480 LTN140AT26L01
        Edit: Added datasheet
        • syntaxzone
          • Jul 2016
          • 15
          • BURHANIYE
          #64
          B156XTN04.3 bios
          B156XTN04.3
          H/W:2A F/W:1
          hi, eprom is dead... i need this lcd screen bios firmware.
          thank you all.
            • 21853
            Re: B156XTN04.3 bios
            Originally posted by syntaxzone
            B156XTN04.3
            H/W:2A F/W:1
            thank you all.
            here.
            • dmlib
              • Sep 2020
              • 4
              I found one dump .Can you post your corrupt one .
              Referring to my earlier post in the subject few months earlier, I share how I could solve the EEPROM issue, which might be also usable
              if anyone runs into this kind of situation.
              In a nutshell: I got an AUO B156HTN03.8 HW:6B FW:1 panel, however it was not working (only backlight). It figured, that the EEPROM FW image
              was damaged in 3 offsets (0x0, 0x100, 0x200), at each locations ca. 10-15 bytes were overwritten with garbage data. First 128 bytes of the
              FW is the EDID, and the rest of the 4096 Bytes is the misc/timing(?) data for this panel.
              I could only find a similar full FW for the panel (same model, but HW:0A FW:1 @SMDFLEA thanks!) with different EDID data, however the
              timing/FW data part was very similar (only 7 bytes differences).
              The correct EDID for my panel is on Github (linuxhw/EDID) and used that as the first 256 bytes for the corrected FW.
              I copied the missing data at offsets 0x100, 0x200 from the similar panel FW correcting the bad one. However, that was not sufficient.
              Eventually figured out, that the data at offsets 0x103-0x107 are EDID style 256 bit (MOD_256) checksums corresponding to parts of the FW.
              0x103-> 1 byte checksum for data in offsets 0x200-0x2ff
              0x104-> 1 byte checksum for data in offsets 0x300-0x3ff
              0x104-> 1 byte checksum for data in offsets 0x400-0x4ff
              0x105-> 1 byte checksum for data in offsets 0x500-0x5ff
              0x106-> 1 byte checksum for data in offsets 0x600-0x6ff
              0x107-> 1 byte checksum for data in offsets 0x700-0x7ff
              So, I only needed to correct the 0x103 and 0x104 checksums, where the timing data for the two panels differed, and voila, it works using both
              preferred timing modes (60Hz and 40Hz).
              I attach as a reference the corrected FW. This method applies to AUO FW only, but might be used with other vendors' panel with apropriate adaptation.
                • 21853
                Re: LCD LED EDID EEPRom Dumps
                HP Elitebook 8440p Samsung LTN140AT05-102
                https://linux-hardware.org/?probe=0799569bca&log=edid
                • shaon_kof
                  • Feb 2014
                  • 41
                  • Bangladesh
                  #68
                  Thanks for the sharing brothers.
                  • karazafer_
                    • Feb 2020
                    • 15
                    • usa
                    #69
                    What kind of problems does a corrupt eprom cause?
                    • Zibbo
                      • Mar 2017
                      • 204
                      • Zimbabwe
                      #70
                      Hi, I am looking for EDID dump for R156B40-189/W-0301
                        • 21853
                        There`s not much info about this screen. Post a picture of the sticker with the model number etc , and post the laptop brand and model number that its from .
                        • kusal
                          • Jul 2021
                          • 28
                          • Sri Lanka
                          #72
                          NEED ivo-m140nwr1 bios
                          alptop lcd rm bin file need
                            • 21853
                            Re: NEED ivo-m140nwr1 bios
                            here you go.
                            • ahkh_72
                              • Dec 2014
                              • 109
                              • Iran
                              #74
                              Hi
                              i need ltn156fl02-101 edid file????
                              .Today should be different from yesterday.
                                • 21853
                                Originally posted by ahkh_72
                                Hi
                                Untested.
                                • Ghamidi
                                  • Mar 2020
                                  • 305
                                  • France
                                  #76
                                  Please need eeprom B156RW01 v1
                                    • 21853
                                    Attached is a dump from a lenovo W510 and a B156RW01 datasheet. The lenovo dump might be different to the standard one. You can make a standard dump from the datasheets EDID description on page 33 and 34. With a hex editor just type everything in the 2 green vertical columns into a new file.Copy the 128bytes FF`s from the end of the W510 dump or type all FF`s to make it up to 256bytes.
                                    EDIT:
                                    https://linux-hardware.org/?probe=4b6be936e4&log=edid
                                    https://github.com/linuxhw/EDID/blob...E/4AD0A1347398
                                    • Ghamidi
                                      • Mar 2020
                                      • 305
                                      • France
                                      #78
                                      thank you so much Sir
                                      • alaasniper3
                                        • Jun 2014
                                        • 13
                                        • jordan
                                        #79
                                        EDID 30 PIN how can i programming eeprom ?
                                          • 21853
                                          If the screen is eDP then you will have to desolder the chip or solder wires to it,and jumper the WP pin to ground. If its LVDS you can do the same or buy a dedicated programming cable or make your own,see post #6.You will also need a programmer.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
