Samsung PN50C450 plasma image lava lamp and sprakles
  • shelby5041
    • Feb 2009
    • 1504
    • united states of america usa
    hi
    plasma tv powers on fine but image is very very grainy with sparkles and red and purple colors...a mess
    once in a while the picture comes in perfect but then after about 2 min it goes bad..and this is random
    i have seen this before on plasmas and i am going to assume its a bad y board
    i have tested Vs Va Vsc and Ve and all are good from the PS and also at the y board
    any input?
    thanks
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Samsung PN50C450 plasma image lava lamp and sprakles
    Try running the test patterns. That way you can rule out the mainboard if display is still bad.
    • shelby5041
      • Feb 2009
      • 1504
      thanks i may have solved the issue ..i thought for a second why would tv have a good pic once in a while but 99% of the time not?
      i tapped on the y board and the picture went perfect...ah ha!!!
      heat plus solder plus melt = possible broken solder joint
      i removed y board and looked around heated areas and found 1 broken solder joint on one of the compoenents under the large heat sinks..i resoldered and picture is ok
      will see if this was the issue..will leave tv on for a while
      • shelby5041
        • Feb 2009
        • 1504
        Tv fix fix.....it also had a secondary issue....a intermittent vertical stripe in same location all time....i put a piece of foamy rubber over the bonded connection in that area...now no vert stripe ....beautiful picture
        • shelby5041
          • Feb 2009
          • 1504
          Look look
            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
            09-12-2024, 02:20 PM
          • piershs
            Toshiba plasma 50WP16 wierd double image fault
            by piershs
            My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
            Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
            • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
            • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
            08-01-2020, 01:07 PM
          • Delired73
            TV LG 50PA4500 Plasma : bad image noisy
            by Delired73
            I have an issue and didn't find any solution by myself or on every forum about my LG plasma TV 50PA4500.
            Originaly the TV stopped to work and didn't want to turn ON again.
            After visual inspection, few transistors were broken, I tried to change them but some burned again, so I ordered on full new board. So, I changed the Yboard which was burned by a new one
            It now turns ON and the image and sound are present. But the image is very noisy and only visible when the room is in the dark.
            I check Vs and Va voltages...
            04-04-2021, 09:13 AM
            HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
            This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
            09-06-2024, 10:56 AM
            HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
            This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
